COBB Tuning - Accessport Flashing Without ECU Removal
#91
Received 3,456 Likes
#92
Nope, still lousy. It was sunny & 80 in Orlando but 62 here on the beach and fog so thick I could not see across A1A, and odds are the weather will not break until next week when a front comes through (can you tell I follow the weather?!). Trust me, when I take her out I will post my thoughts here when I get back home!
#96
Very interested in this one. Are most people doing this ECU flash also pairing it with Cobb's high flow filter install? My understanding is its 2-3 hours of labor on the 991.2 to get that thing installed.
#98
OEM filter flows well with high flow cats on the GTS and I have no plans to change it, and I may even load the Stage 2 Map w/93 depending on how the Stage 1 is but I am inclined to stick with Stage 1 so as to not over stress things.
#99
No high flow cats on my GTS, straight stock. Figure Cobb is recommending the high flow filter with the tune for a reason, other than an extra $300 in their pocket? Abundance of caution, or maybe a small perf gain?
#100
Those who think that they are smarter than the tuner, in this case COBB, is going down a slippery slope. No student is smarter than the master. There's a reason why a stage 2 tune requires better airflow with high flow cats/cat bypass and high flow air filter. I won't beat this horse to death anymore as it's dead and gone to horsey heaven. Ask yourselves, do ya feel lucky punk? Well, do ya?Seriously folks, are you willing to bet on your laziness and cheap out by not spending the extra $300 for a high flow filter on your beloved 6 figure beast?!?! The Darwin Award Society is always looking for more recipients.
#101
#102
Better yet Darwin, let me quote them: "We actually have a good chunk of GTS owners using Stage 2 maps with that configuration. Since the car comes with a higher flowing exhaust standard, the high flow cats are all that is required."
#103
Think of this logically, the Base and the GTS use the same air filters.
#104
No high flow filter here...452 whp with just the stage 1 OTS tune (no hardware changes). Currently running cat bypass pipes and a protune with the stock filter...no issues. I will replace eventually-but it’s not because of performance gains-really just to be able to wash/reuse.
#105
