Burger Motorsports JB4 Tuning Systems Available Now!
#196
Originally Posted by NightBlueTTS
Sorry, I should have been more precise. While the boost target is higher across the rev range (during WOT), the boost doesn’t really get close to the +4psi target until higher in the revs. So either the turbo is operating at max capacity and can’t build boost any faster or the wastegate isn’t being managed as efficiently as possible to build the boost faster.
This is why I would be really interested in seeing a dyno. The way this looks to me is that the peak HP differential only really occurs in the upper revs vs across the rev range. But then again I could be misinterpreting this..
here are logs of map 6, map 3, and map 0 (4.2 target, +4 vs disabled):
I have no history with JB 4 and would not criticize them I'm just wondering why you are taking this route.
#197
If you don't care whether the tune is detectable or not why not then go for a Pro tune. Cobb or others and have a Pro Tune done. If stealth is not your worry why go piggy back?
Just don’t want to physically modify the ecu at this time
#198
NightBlueTTS said:
"While the boost target is higher across the rev range (during WOT), the boost doesn’t really get close to the +4psi target until higher in the revs. So either the turbo is operating at max capacity and can’t build boost any faster or the wastegate isn’t being managed as efficiently as possible to build the boost faster."
That is exactly how my totally stock C2S/X51 boost behaves. To compensate for this, i cruise around 3000 rpm, and lag is reduced. But peak boost doesn't seem to come on till 5000+ rpm. So how would this also be a negative for the JB4?
Here is my thought - Maybe Porsche programmed so as not to build boost too rapidly, so that oil pressure is sufficient to handle living sufficiently for higher boost.
#199
With cobb u hit 23 psi at 3k rpm on a base. The car can do it the question is does the drivetrain play nice. When youre piggybacking off accessory tables expect less aggressive delivery down low. Much safer but it starts behaving alot more turbo laggy than stock. Unless burger has some tricks to combat this, which they might. But thats the nature of a piggy back
The following 2 users liked this post by Rennolazine:
Aatish (08-12-2019),
NightBlueTTS (08-12-2019)
#200
That is exactly how my totally stock C2S/X51 boost behaves. To compensate for this, cruise around 3000 rpm, and lag is reduced. But peak bossy doesn't seem to come on till 5000+ rpm. So how would this also be a negative for the JB4?
#201
We'll take a look at boost and what it's requesting and when.
-Payam
#202
What I'm worried about, is that until now, there's no real proof that the claims of this product are true. No dyno numbers or curves so I'm wondering how they can even provide some numbers without previous testing. Other tune manufacturers extensively test their software before releasing them and they can provide numbers and curves because of these testings, but in this case there's nothing. If that's the case, how we even know that the tune doesn't have any flaws that could seriously affect your cars ?
Last week I was about to place an order for this tune but know I have decided to wait or pass since no information has been able to be provided despite several of people asking for it.
If you feel skeptical about us, you can take a look at my data and dynojet numbers from my 991.1 TTS
https://rennlist.com/forums/991-turb...lable-now.html
https://rennlist.com/forums/991-turb...28-2019-a.html
-Payam
#203
I just emailed some to you. I can get the ones in the post above later. But the ones I emailed to you show maps 0, 3, and 6 in 4th gear from 3000-5000rpms
#204
Im praying BootMod3 makes it way to Porsche. Those guys came out of nowhere in the BMW world, took over OBD2 flashing and now dominate it as far as I'm concerned. Their tunes ran so smooth and allowed us to change the duration and aggression of our exhaust "pops" which was kind of fun to be able to change each driver mode to a different pop sound. You could remove the pops all together if you wanted too as well. All from the iphone too. You could even set the boost per gear from your iphone app among many other things.
I pray they make it over here sooner than later.
The following 2 users liked this post by BIGWORM:
Mark Mullins (04-26-2020),
Omega4 (08-12-2019)
#206
Dzenan actually has badass 997.2 that he built and tuned himself.
I'm praying with you on this. That said, unless the market becomes worth their time, it probably wont happen anytime soon.
The through OBD for BMW was through an internal leak from a BMW employee.
#207
We've sold a ton of these. Where are you guys!? Post up some logs or Dragy results
If you don't have a Dragy, you can get one here:
https://burgertuning.com/products/dr...08de8927&_ss=r
-Payam
-Payam
#208
Did some more logs last night. All done on 91 shell v-power form CA
If anyone can take a look and see if everything looks good?
I am planning to do dyno and get dragy to see how real numbers looks, but my butt dyno tells me it is more powerful than stock.
I feel bigger lag on low rpm but after turbos spools it is QUICK. Map 2 felt much stronger but didnt want to drive on it too much with our low octane fuel.
#210
