BMS JB4 991.1 Turbo S at Shift Sector 4/28/2019
Former Vendor
Had a chance to race at Shift Sector a couple of weeks ago. Finally got the chance to edit the videos and compile some data
I was running the BMS 991.1 Turbo S did a best trap of ~166mph Dragy and timing equipment verified.
The car did a stock run of 152 mph at NFZ on 91 octane only. 14mph delta with JB4 and Mods:
BMS JB4, E50 Blend. No FLASH, No METHANOL.
BMS Intakes
BMS Y Pipe
IPD Plenum
Fuel-it/BMS Chargepipe Port Injection
Straight pipe from turbo back (Race Exhaust)
Car was very consistent back to back, no issues what so ever. I love this beast
Log shows a peak boost of 20 psi tapering down to 17 psi.
Enjoy the video and data below!
BMS Intakes
BMS Y Pipe
IPD Plenum
Former Vendor
What specific details would you like on the mods? I can upload pictures if you'd like to see.
Pricing will be released once we become a vendor next month. Pricing will be much lower than the competitors, as always
All made in USA
Yes, my apologies. That M5 is not stock. It is running our BMS Intake system and our JB4 system on Ms109 at 26 psi Map 5. It's at about 700whp in those races, trapping 163 mph. No slouch!
Yes sir! Stock fuel lines and intercoolers
All made in USA
All made in USA
All made in USA
All made in USA
Thanks. Very Impressive on reasonable boost. I'm surprised the factory boost in the csv file was that low before your target. So the Fuel It is dropping the AIT ?
Former Vendor
Factory boost curve will be under IGN Average tab, so you can see it better.
Yes, once the PI starts you can see the IAT drop as it is giving more fuel and cooling the air. Just like what methanol injection would do
Former Vendor
Our F90 M5 runs 10.29@136mph JB4 only on race gas. They are actually very similar in terms of performance tune only and mildly modified. The TTS obviously has a huge advantage in the number of mods out though and what you can do with it given enough money.
Totally agree with the 991.1 TTS comparison. The 991.2 TTS is a different animal. My 991.2 TTS went 10.4 at 131mph pure stock on pump gas. My F90 ran 11.2 at 124 pure stock on pump gas. Same track. Plus 3000ft DA. Start adding a mild tune, RaceGas etc., all bets are off.....
I am trying to understand the JB4 and your tuning philosophy if you can help me shed some light.
The key drivers of increased performance here are the hardware changes and using ethanol to keep the IATs cooler, which as a result, will reduce ignition timing retardation and keep boost levels higher and optimized by the factory ECU.. Given that you are not doing any tuning, you are leaving boost control to be managed by the factory programming rather than using a Cobb which will have set and fixed boost control.
But the factory fueling is more than enough for the 1.4-1.5 bar of boost, the only reason you would add more fuel is because ethanol has a higher BSFC vs. gasoline, and therefore requires more fuel to burn the same unit of air, otherwise it would not be needed, and is that what the "fuel-it" does exactly?
Am I right in assuming that this is the sort of same as adding a Y pipe, IPD, methanol spray and keeping the factory programming?
First of all it's great to have you here as a sponsor, we all welcome and support professionals bringing new ideas!
“Fuel It” is an added injector to add octane over pump fuel and possibly more fuel also as he is using a 991.1 which does not have as much fuel volume capacity as a 991.2 for increased boost levels. Probably used for both reasons. Added octane plus lower AIT tag teams for no timing retard by the DME, plus adds detonation safety at higher boost levels and higher loads.
JB4 does Control the boost level by altering the signals through the Map Sensors by RPM via Can. Probably can be used without Fuel It, etc just to increase the boost on a 991.2 around 3psi on pump gas for a nice power bump and easy installation.
