Fuel Tank Squeaks
#61
This may help (Jeff has a whole series of helpful 981 videos):
(656) TSB 1403. Squeaking from fuel tank | Planet-9 Porsche Forum
One other:
(656) Fuel tank squeaking easy fix found | Page 2 | Planet-9 Porsche Forum
One other:
#62
Is this squeak everyone is hearing? Trying to figure out if this is the same thing...
https://youtu.be/K3BMkUKp1wg
#63
#64
Did you need to get an alignment after the bushings were replaced? My local shop is saying that I will need an alignment as they will need to drop the front sub-frame to access the swaybar bushings.
#65
#66
Here’s a good test to see if it’s your fuel tank or something else. If your fuel tank is 3/4 full or less then it doesn’t squeak anymore then it’s your fuel tank
Titanium5150 (11-17-2023)
