CT Owners: where to turn off Power Steering Plus?
The local (Fairfield) dealer refused claiming liability-based restrictions.
Porsche should be embarrassed about this system and twice as ashamed about preventing its disablement.
My other cars have hydraulic steering racks and I feel this is the single biggest weakness of the 991.1 platform.
Received 3,460 Likes
Try another dealer as many here have paid to do so, about 1 hour labor.
OH, it's also possible to update the steering software to the 991.2... as me how I know! I have a piwis II. It is possible.
PatrickBateman (05-11-2022)
Received 1,679 Likes
At the main diagnostics menu, there is a button on the bottom row, hover over it and it shows "addt'l menu" click that, then click on "Maintenance of Vehicle Data" and once at this terminal use the f12 button to move through the menus until the "Z" menu, then scroll down, down, down until you find "Speed Sensitive Steering" you unselect that, you will also need to unselect "ServoTronic" steering and enable "Standard Power Steering" from the same list. Then click next in the lower right corner and "Save" the options. Voila done.
Martin S. (02-15-2023)
re-read it and realize you weren't asking "how" to do this within PIWIS, but "where" as in which dealerships in Connecticut would do it for you! DOH, first post and it was a fail.
oh well, use the info as you wish and for anyone in the Bay Area who would like their steering software updated to the 991.2 version I am willing to do so for a small reward.
But what is the diff between .1 and .2 steering?
great information. in the true spirit of technical forums. thanks!
I think there are some forum posts here and on other forums talking about how the .1 steering felt a bit numb while the .2 steering software provided those cars with a more organic feel. From doing this on my own 991.1 C2S I was able to first disable the Power Steering Plus and drove it - noted that the steering felt very heavy and a lot like my wife's 2007 Lexus IS 250. I managed to force update the electric steering and I have to assume it's the latest source code because now the steering feel is a bit softer and there is some road feel coming back through the wheel (it's not as much as a hydraulic system but it's noticeable).
That's the best way in which I could describe it. I personally prefer the updated steering software.
That was what I'd heard as well -- that PSP only affects low speed steering, phases out and "regular" steering takes over -- in my experience playing around with the settings that's not entirely the case. With PSP enabled, the entire steering programming is markedly different at all speeds. Now, bear in mind there are a few more variables -- there is ServoTronic and Standard power steering options in the Vehicle Data settings, there is also yet another option to enable/disable Power Steering completely.
I also did one experiment where I changed the vehicle's designation from a Carrera to a GT3 to see if I could get the GT3 algorithms installed but unfortunately that essentially broke many of the systems in the car and I had to roll that back, it's simply not an option.
What is interesting is that I'm able to do a Manual coding and can select either 911 or Boxster/Cayman steering modules and software. My guess is that the Boxster/Cayman steering software would in fact port in to the 911.
PSP makes the wheel turning extremely light and easy at parking lot speeds, turning it off and setting to the 991.1 steering makes the wheel turning feel very heavy at all speeds -- there is no gradation as the speed of the vehicle increases to the steering becoming lighter. Updating the steering to what I believe is 991.2 makes the steering wheel require less force to rotate at all speeds but not as light as with PSP. It's in the middle somewhere.
It can also be described as having a very small feeling of "lightness" at the first pressure to either direction which then firms up as you change lanes on the expressway for example.
Originally Posted by n8kruger
Call MIchael at Porsche of Wallingford. 203 269-3317. He said they'd be happy to do it. You may need to show them the instructions in the above thread
More importantly, is this process reversible if I end up disliking the new setting or do i have to purchase another license key in order to re enable PSP? I don't mind playing with different configurations until I get to a set of settings that i like but not willing to break the bank in the process.
After reading many forum posts, it seems PSP was developed for elderly men under 150 lbs and women under 110 lbs. Those with weaker and more slender arms may need additional power steering assistance for parking and parking lot maneuvering. It's hard to imagine a typical man or normal woman who finds the standard 991.2 steering too strenuous to operate.
