991 GTS - P2295 DTC
Help me diagnose this : the car, a 2018 GTS, was sitting for the last two weeks with battery and ecu disconnected. Today I tried to start the car : very rough idle, a lot of smoke, an error message about power reduction mode, and MIL on. Scanned with an obd2 scanner, P2295 error. It is a bank2 fuel pressure regulator circuit low voltage. Where I have to look??
Diagnostic information DME
(DFI) control unit
Quantity control valve driver
Diagnostic conditions
I Ignition on > 5 second(s)
Possible fault causes
J Loose contact or corrosion on connectors or lines
J Short circuit to B+/ground/between lines or open circuit in the lines
J Quantity control valve faulty (in fuel highpressure
pump)
Get a battery tender and store the car with everything connected. I've done this for up to 3 weeks, while traveling, with no issues on return. Some here store their cars all winter this way too.
Here is the verbiage for Code 2295
(DFI) control unit
pump)
(DFI) control unit
pump)
