991 C4 Cranking but not starting.
So this morning I started the day poorly. Got into my 991 C4, turn the key and the car cranked over and over but didn’t start. Tried a couple more times with the same result. It cranks hard without any sign of battery issues. I drove the car last night and it worked perfectly with no signs of any incoming issues. Any ideas before I call Porsche for a flat bed. The car is in my garage which isn’t too easy to extract.
Ignition fused blown? I know this is a different car, but my truck did the same with the ignition fuse pulled. I was working on it and had the fuse out. The truck would just turn over and over but not start until I put the fuse back in. Just a guess.
Do you hear the fuel pumps kicking in?
Good call! I'm going to look at the Fuse box and see if I can find the one for the fuel pumps.
