GIAC VS COBB on 991.2
Interested which has the more aggressive tune for a 991.2 GTS. I've seen a lot of COBB threads but not many GIAC. My local tuner prefers GIAC
I have installed Cobb AP twice on 2 different Pcars. Have it installed on my TTS . I believe that it is the best out there right now and they are very customer oriented. I have talked with them several times during my 1st install process, very helpful and know what they are doing. No disrespect to GIAC at all.
The basic cobb tune may not be more aggresive than the GIAC tune, but it is far more flexible given you can quickly change tunes as you add mods (once they release the stage 2 tunes)
and you could get a very aggressive Pro tune for your car if needed.
The Porsche dealership in Austin actually promotes and sells the GIAC tune for both new and used cars. How they deal with warranty issues on the engines isn't clear to me, but if asked I'd guess they'd have an answer. I've opted not to roll that set of dice so I haven't asked.
So if your transmision goes, porsche will investigate. If your water pump is leaking, probably no problem.
Un-installing is good, as the dealer could update the software and overwrite the tune removing it. After an update, you can re-install over the updated software.
With the GIAC, better not get a software update by Porsche ( or your going to have to remove your ECU and send it in again to get the tune back).
Now if your dealer is your GIAC installer, they would still have to send the ECU to GIAC to get it fixed ( I believe)..
