Cracked Oil Drain Plug!
Old Feb 14, 2020 | 10:34 PM
  #46
0luke1's Avatar
0luke1
From: South Florida and Jersey shore (Monmouth County,)
It’s nice on the rocks
Old Feb 15, 2020 | 10:45 AM
  #47
IXLR8's Avatar
IXLR8
Originally Posted by BOPE
That wouldn't happen to be a KLR 650 motorcycle, would it? There are many of those with stripped drain plug threads in the engine case.
Jason
Nope, I bought the KLR650 new but did the doohickey mod to avoid future issues. Anything I buy new never gets a stripped fastener.
No, it happened to a 1986 BMW R80 G/S Paris Dakar I bought used. I knew about it, but the deal was too good...used a Time-Sert to fix it. The drain bolt for the swingarm which is easily stripped if the previous owner(s) were clueless (they used a pipe plug and tape to seal it) . And reusing a sealing ring a kazillion times did not help, I am sure.
Old Feb 15, 2020 | 01:23 PM
  #48
cvtbenhogan's Avatar
cvtbenhogan
Get the LN magnetic plug. FCP euro has it for $26 and a $49 order gets free shipping. FCP has tons of good stuff.
I torque most bolts. But just finger tight for oil plugs and never a problem.
That said, yesterday I broke water pump bolt on my BMW. The torque for that bolt was a mere 18 inch lbs. Arghh. I was lucky to get the bolt out.
Old Feb 15, 2020 | 05:25 PM
  #49
PP4's Avatar
PP4
Originally Posted by CSK 911 C4S
This is for 991.1's with the metal oil pan.
​​​​​​Oil drain plug to oil pan M18 x 1.5 – replace sealing ring Tightening torque 50 Nm (37 ftlb.)
Oil filter cover Replace and grease O-ring Tightening torque 25 Nm (19 ftlb.)
Well, that is amazing! But obviously correct so direagard my previous post, what do I know about 991's...Pany clearly has a softer pan 😏
Happy motoring 👍
Old Feb 15, 2020 | 07:38 PM
  #50
991carreradriver's Avatar
991carreradriver
Originally Posted by Porsche_nuts
First I am hearing that plug needs to be changed with every oil change too!
I don't recall what I did in my C2's but when I order a filter from Suncoast for my GT3, I receive three drain plugs and crush washers. I replace the drain plugs with every oil change.
Old Mar 2, 2020 | 10:45 AM
  #51
IXLR8's Avatar
IXLR8
Originally Posted by PsychicDreamer
I torque this drain plug to the spec of 37 foot pounds.
I just got an on-dash display telling me to replace the differential lube on my daily driver that has an aluminum case.
The factory manual calls for 35 lbf.ft. for both the M18 and M20 plugs. So it is not out of the ordinary.
