GTS Middle Light Install
Old 08-07-2024, 09:04 AM
  #151
c1pher
c1pher's Avatar
Just to summarize, you only need the lightbar and the connector? When I search for the connector, it looks like it is no longer carried and there is a replacement. Is that correct? I don’t want to screw up and order the incorrect one. Any help is greatly appreciated.
Old 08-15-2024, 10:32 AM
  #152
GiGNet
GiGNet's Avatar
@cipher from what I read here you can do this one of two ways. 1) Get just the light connector and splice it into the license plate power wire (can't find that part # though) or 2) using the guidance earlier in this thread and connectors from DeyTrade you can build a simple Y-Harness that taps into the license plate power without having to splice wires, therefore making the mod much cleaner and more factory like.
The following 2 users liked this post by GiGNet:
c1pher (08-16-2024), cbredesen (08-15-2024)
Old 08-16-2024, 08:55 PM
  #153
c1pher
c1pher's Avatar
Thank you for the clarification!
Old 08-18-2024, 04:25 AM
  #154
basic666
basic666's Avatar
have anyone had luck finding the middle light part (991-631-465-02) anywhere?
I can only find items with a "-03" at the end instead of the "02", like this one https://www.sunsetporscheparts.com/o...el-99163146503
Can someone confirm if this is the right part or share a link to purchase the right part?
Old 08-18-2024, 07:45 AM
  #155
krburrell
krburrell's Avatar
The latest part number is the “-03” part. It has replaced the 991-631-465-02 part number.
basic666 (08-18-2024)
Old 08-18-2024, 08:15 AM
  #156
GiGNet
GiGNet's Avatar
Default And she’s done!!
Completed the mod yesterday. Came out great! Thx to all the folks on this thread that provided guidance!
The following 3 users liked this post by GiGNet:
basic666 (08-18-2024), thesaintusa (08-18-2024), Tier1Terrier (08-18-2024)
Old 08-18-2024, 11:43 AM
  #157
basic666
basic666's Avatar
thanks @krburrell
And @GiGNet which method did you end up going with? To clarify for the splicing, I would only need the light itself, and this cable from Delray https://www.automotive-connectors.co...i-neutral.html
Old 08-18-2024, 12:46 PM
  #158
c1pher
c1pher's Avatar
I got mine at Porsche Delaware. Arrived in about a week.
Old 08-18-2024, 07:10 PM
  #159
GiGNet
GiGNet's Avatar
I ended up sourcing the plug from a local junk yard. As it turns out, the plug for the center light is actually quite common on Audi, VW and Porsche - it's a rear parking sensor connector plug. I went to a junk yard and got the plug with a pigtail for $10 that came off a wrecked Audi A6. Super cheap and simple. I did have to just slightly trim the one little notch of the plug to fit exactly right but that took two seconds with a razor knife. Again, super easy. Then I used the idea from @LWG and just tapped the license plate light on the right side, taped it up really well, wired tied the new harness to the factory wires above the license plate and done!
basic666 (08-19-2024)
Old 08-22-2024, 08:53 PM
  #160
c1pher
c1pher's Avatar
YAY!
The following 2 users liked this post by c1pher:
GiGNet (08-22-2024), roketman (Yesterday)
Old Yesterday, 10:40 PM
  #161
roketman
roketman's Avatar
Default Light bar
Originally Posted by Revsportz
Do you have a GTS rear bumper or the Carrera T rear still? I have a T as well and been wanting to do this mod for a while.
thanks,
yes GT’S bumper
Quick Reply: GTS Middle Light Install
