The Porsche Roof Transport System is INCREDIBLE!
#107
Lift up the rubber strip on your Turbo S and make sure the attachment points are there. You should be GTG.
#108
Thank you, much appreciated.
The dealer has said this car does not have the code for the points on the spec sheet. Is this a thing or is there a reason there would not be?
Thanks again
Thanks again
#109
#110
Maybe others can comment (or are smarter
but I didn't find the OEM system that great. Pulling up the rubber channel grommets a lot and routing them around the uprights for the PTS distorts them and when not in use they don't sit flush any more.
I bought a sea sucker for bike transport and found it pretty awesome. Only once did on of the suction cups loosen on a 4.5 hour drive and that was easily found while gassing up!
Good luck with the purcase @civerinos
#111
I've heard great things about the Sea Suckers but I'm too OCD and the idea of a suction cup coming loose, although I'm sure it happens only seldomly, would drive me nuts. Only if there wasn't an OEM option, or otherwise suitable system from a company like Thule, Yakima, or Inno would I consider the Sea Suckers. But I konw that people who have them love them. I use my rack mostly for rooftop cargo boxes and I just wouldn't trust them at high speeds with such a large wind resisting object on top of them.
I don't think I ever updated this thread with my videos of the Porsche RTS, but here are a couple I made really highlighting it's function.
#112
#114
Hi everyone, little late to the party but im looking for some advice.
I am just in the process of buying a 2015 991 turbo S. I Really need the transport system on this vehicle and the dealership has said this model does not have the system listed on the build spec.
I thought it was standard issue.
Could they be wrong?
Thanks in advance for any help.
