Finally got my T! Impressions, Review and Mods!
#121
+100%. I love that feature too!
I see that it is referred to as the 'backfire' feature in the photo of the manual above.
#122
So if in Individual Mode if it's set to Sport checked and Sport Chassis unchecked, you don't get the Sport Chassis but all the sound right? or is it the same if you just simply engage Sport mode all together instead Invididual model like you said.
#123
Hi. I haven't checked out Individual mode at all. I've just been leaving in Normal mode, or turning the controller on the steering wheel to Sport or Sport Plus modes. When I change from Normal to Sport mode, this switches on the PSE and rev matching, and it turns off the Auto Stop/Start function. It does not turn on the Sport chassis setting. If I then change from Sport to Sport Plus mode, the Sport chassis is then switched on. Or, when in Sport mode, I can just turn on the Sport chassis setting by pressing the button manually.
#125
Leather upgrade
Can someone plz post a pic of the leather upgrade instead of the gloss black trim ! I am on the fence and have a few weeks to make the edit.
cheers
matt
cheers
matt
#126
cheers
matt
cheers
matt
It looks great, and you get no scratches, dust, fingerprints, etc.
Here you go!
#127
#128
I was gonna switch to leather wheel & add trim as i feel like it will look bad after a year or so u know.
#129
Question for Alex...When you did your build sheet you had to select the interior leather trim option as code EKC? If I am getting the full leather interior but want the piano key gloss black trim on the cupholders and doors, I just omit selection of the EKC code then correct?
#130
That is correct. EKC will replace the black gloss trim with the leather trim.
#131
Thx Alex
#132
I would recommend it if you got the full leather interior. Otherwise, it looks a little odd -in my opinion- as the leather pieces looks quite different from the vinyl on the dash and looks out of place. If partial leather, I would go regular gloss trim. Full leather, I would go with leather trim.
Plus, as my previous car was a 2017 Panamera 4, I'd had my fill of black, shiny trim.
#134
@andial how ?
#135
@andial how ?
