I Don't Know Jack! Floor Jacks..
I have 2 ea. 2 ton 'Professional' jacks made by JEGS. This jack apparently has other labels. Also 4 of the jack point jack stands, and 4 high quality jack pads made by Reverselogic that 'lock' on the underside of the car. It's not really locked but stays attached to the car. For the jack pads, the oval piece is inserted into the hole at the jack point, and rotated 90 degrees. At that point it is hanging on the underside of the car and they work great. They are high quality and the owner of the company is great to work with, as is the owner of Jackpoint.
I looked at the Jackpoint jack stands and think they are probably perfect for the 911 but I wanted to also use them on the Macan and not sure they would be tall enough.
I placed and order for these last week, a bit more flexible in height, permanently out of stock so will see how long they take to get here...https://safejacks.com/products/2-pac...d-by-safe-jack
I really want some. I just don't want to pay for them.
The RennLine pads or the Jackpoints make more sense, or any of the nicer jacks mentioned above that include a rubbery pad built-in.
I forgot to mention, depending on what you are doing under the car, Race Ramps work great too.
https://www.amazon.com/s/?ie=UTF8&ke...l_7i5bkzwmym_e
I'm with LexVan. Here is the hockey puck pad with a cam-locking mechanism I bought online. It disintegrated on what I think was the third use. Without the lock keeping it in place the car might have shifted on the jack when it crumbled. Its not worth the risk to the car or my body in my opinion.
I'm not some sort of overzealous advocate for hockey pucks here. I'm just saying they seem to work well for basic maintenance tasks.
Whoa. What IS that? I can't see that happening with actual hockey pucks. I'm wondering if that was some cheap thing meant to serve the same purpose but that really didn't hold up.
I put a pair of those on my Christmas wish list to no avail! Good suggestion I think. It's not completely clear to me which one would work without causing approach angle problems, striking the body before the tire gets on the ramp... especially with a SPASM car. Any suggestion?
Thanks for going to the trouble! Using the Amazon link you gave earlier it appears those just happen to be the first ones that pop up. I'll put those on my short list of goodies to get.
https://www.amazon.com/Race-Ramps-RR...ef=sr_1_1_sspa
Are the Harbor Freight ones better built than back in the mid-2000s? Mine developed a leak after about three years of use and would very slowly drop. Got one from Costco (thanks AOW162435!) and have never had an issue. Still have the HF for the few times when I need to jack up both sides of the car.
Or better... these one-piece ones for less $. https://www.amazon.com/dp/B003WSZH9G...pa_dk_detail_5
