Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#227
#229
#230
PM sent to purchase CarPlay system with backup camera.
For those concerned with installing the board in the pcm I asked Nick if a computer tech was a good option for installing the CarPlay board and his reply was yes that would be a good option as they wouldn't have any problem with the install.
Cman21
Cman21
#233
#237
It's a possibility for PCM4 Probably a little earlier yet as PCM4 is still relatively new even though it's shortly to be replaced as the Cayenne, Panamera, new Macan etc.
#238
For those like myself installing the aftermarket camera, please note that the guidelines are way off. I contacted Nick about this and he is looking into it. As you can see in the pictures below, in the first picture the guidelines make you think that you are going to miss the object, but as you can see in the second picture, I would hit it. Basically, if you see the object in your screen, you will hit it. I think this is more a problem of the lens or camera placement than the guidelines itself.
#239
