Better phone mount?
#46
I've got the Rennline solution from Suncoast. Mounted permanently to the right side of the manual shifter. Only disappointment was that the magnets wouldn't stick to the back of the iPhone 8 itself, due to the glass back, so had to mount the magnet on a case. I've got the Plus, so didn't really want a case on an already huge phone. But the holder itself is very slick when mounted and the magnet works great. Recommended.
sr5959 (07-09-2019)
#47
I normally use a different one from Rennline for my phone, but for a higher level mount that might work well for navigation I'm using this one to hold the phone on the windshield (for some recent testing where I needed the camera to see out of the car). Its sticky cup is amazingly strong and takes quite a pull to remove and the height, depth, and orientation is adjustable, just above the left vent. The design for the engagement of the phone is really cool, making it easy to mount/dismount the phone. The photos show it dash mounted but it windshield mounts just as well. Its not expensive either. The only possible downside is seeing the sticky cup's backside on the windshield... if that bothers you.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Mounted to the upper left of the steering wheel you an adjust it to a position just far enough back from the steering wheel to be out of the way but close enough for easy reading and interaction. Mounted in the center puts it further away and may not be as good for your use but worked well for taking video; there it holds the phone just a little closer than the sport chrono clock. And as with all Amazon things it is easy to return if you don't like it. It's very popular and highly reviewed, check the Amazon ratings.
wheel.
#49
#50
Hands down this has been the best mount in my experience. I had similar versions in the C2S and Cayanne GTS but recently upgraded to this. Like py0413's this is a vent mount and the phone does obscure the vent. But it's at the perfect eye level location without being on the dash.
It is rock solid in the vent. That's a iPhone 6s for scale.
991Targa4S (01-24-2022)
#52
Do you have the link to this one? I tried a few vent mounts but they all drooped with phone weight
#53
Koven, yes here it is on Amazon. The name is a
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Lamicall Car Phone Mount
#54
#55
I use the Rennline mount but instead of using the magnetic portion of the mount, I use a mount that I purchased from Amazon that holds the phone with a plastic screw that fits directly onto the Rennline mount. I’ll have to post a picture later.
#56
My case with magnetic attachment into a leather folder with magnetic clasp cover works great with my Samsung Galaxy Note 9. And so do the wireless fast chargers. Mag mount? Never a problem.
I'm not mounting my phone in front of an AC vent because i live in Central FL and Summer in the Chicago burbs.. I need that AC air flow.
The Rennline console magnetic mount is the only option that can work for me. Works great!
#57
Interesting. Please post pics when you get a chance.
#58
I have been using the Rennline mount but in the hot sun the glue gives out. I removed the leather from my iPhone case and cleaned the plastic off, and applied a brand new metal plate and the same happened. The glue they use is not very heat tolerant. Next step.....drilling multiple holes and stitching the plate onto my iPhone case.
Mike
Mike
#59
I bought a T-Design mount when I had a Cayman and it had a snug fit to the right of the PCM. When I traded and got a 911, there seemed to be a hair more space and a looser fit. I just wrapped the insert place of the phone mount in some masking and packing tape and it now fits like a glove. Over time I did have one of the foam pads fall off but is a non-issue for me since I use a case on my phone and it still stays secure. You do lose use of the left cup holder, but not a big deal for me.
#60
I’ve had the Rennline mounted on the right side of lower console for close to a year. It doesn’t work for my needs. I thought the magnet might be strong enough to hold with the metal disc mounted on the inside of my phone case between the back of the phone and case, but it doesn’t hold well enough. I’m sure if the metes disc was outside the case it would work better, but I don’t want that. So, while it may work for so
e folks, if your case selection is important and you don’t want a metal disc stuck on the outside, the rennline is probably not your best choice. I’ll have to go back through this thread to find something else. If not for Apple CarPlay, I’d really be screwed.
