A quick review
A quick review
Hello guys and gals,
My name is Sam and I was on the GT3 list for a long time and my build date was November (now delayed). Long story short, I was lured into one of the first two Turbo S launch cars my dealer got Thursday. I bought it after a 1 minute test drive. I took it to the track after 114 miles, which is good enough (I hope). I traded a 991 C4S that I bought in January and tracked extensively. I've owned P cars before but never a Turbo. I will point out my observations during two track sessions Saturday, thought you may be interested. Remember, I am comparing it to an all wheel drive 991, the C4S.
1-Of course, gobs of power. Heart rate up there but you all knew that.
2-Very noticeable difference in all wheel traction. While I frequently questioned if the front tires where doing much in the C4S, the percentage increase of torque input to the front in the Turbo is noticeable. The car gets pulled out of corners much easier.
3-RWS. Yes it is imperceptible but if you are tracking this car after another without it, it is most certainly noticeable because the car turns in much easier and lead to me to hit the apexes (?apices) earlier despite using the same turn in points as before. Once I figured it out, it was great. According to my AIM Solo, most of my min speeds where up 3-5 mph!! And that's in a car that is 300 lbs heavier. Same tires, so the min speed increase should be due to RWS.
4-The new PCCB are shockingly good. As I mentioned on the GT3 thread, I ended up using the same breaking points that I used for the C4S despite a 10-15 mph increase in speed. Zero fade. In the C4S, I used Motul 600 and I had little albeit noticeable at the end of the session. Here, none, with stock fluid.
5-PDCC. This car is softer on the road than the C4S so I was worried it would lean excessively on track. Not so, the PDCC does an awesome job at minimizing lean, it's almost perfect.
6-Lap times. I am used to the local track (Motorsport Ranch in Cresson, TX, 70 miles away) and have consistent lap times there. The fastest I have done in my C4S on street tires, in a clockwise direction was 1:25:xx. In the Turbo S? 1:22:xx!!!! Mind you, I used to outrun GTRs on street tires, so it is not just the brutal acceleration, it's that plus the RWS plus the PCCBs plus whatever else is in there!! This thing blew my mind off and everyone at the track drooled.
7-Exhaust note. In normal and sport mode, sucks. In sport plus, its good (compared to the C4S sport exhaust which was flipping awesome), so that will need an upgrade. I rode with a friend of mine in his 997 TTS before and the 991's is definitely better but needs improvement, by a lot. Some may like it that way but I don't. If anyone has advice as to which is the best system (likely not available yet), please let me know. I heard Europipes and Sharkwerks.
8-Bermister. I had that in the C4S as well and if you ordered one, be prepared for an incredible experience. I had a Jag with Bang and Olfson and this trumps it. I have a new Range Rover Sport with Meridien and this trumps it too. Well worth the dough.
For the street, it is a less harsh ride than the C4S but waaaaaaaaaaaaaaaay more powerful. Scary powerful. My wife giggled when I floored it, then she said "this is much smoother than the other car". Yeah, I need a better exhaust. In our tight driveway at home, it is noticeable that the turning radius is smaller by a lot, thanks to RWS. Made my garbage can avoidance much easier.
I do not regret taking this over the GT3 and I am certain that if they put the same tires on both cars, the TTS will be faster than the GT3 on the 'ring but the tires won't last much at all. I have a deposit on the GT3 RS but not sure I'll do the trade in 1 1/2 years when my turn comes. Heck, I'm itching without the TTS tonight as it gets the Expel clear film put on it.
I hope this helps. What a car!!
Sam
PS: Understeer. Unquestionably less on the TTS in slower tight corners. Probably because of RWS as well.
Sam
No question it is a huge leap over the C4S. I'd like to see the comparison to your buddies 997 Turbo S, especially if he has a tune and Euro Pipe.
Congrats om the new ride!
Walt
Walt
Great review, thanks! Do you have the sportdesign side mirrors, and if so, did you notice if the buffeting problem is gone w/ windows down at the track?
Aside from the exhaust note, anything you miss compared w/ the C4S? How is the turbo lag?
To what do you attribute to a softer ride vs. the C4S, the weight?
Thanks again, post pics when you can!
I will. It's at the shop getting Expel clear wrap. Going to the track again Thursday, this time counterclockwise. I will also remove all the literature on the back and simply put "S" because stock chrome script is too flashy for my taste. There is a lot of red lights in the back but I'm thinking of painting the S yellow (to flow with the calipers).
I do not miss the C4S a bit (exhaust excluded). There is clear Turbo lag if you are in lower RPM in higher gears. I have the Turbo boost meter on the display and if I am in, for example, fourth gear at 2,000 RPM and floor it, you see the boost go up, not much accelerations then BAM! On the track, no lag and it seemed like the turbos where always spooled up. Not sure why is it softer, perhaps tuned that way intentionally?
Sam
We should meet up sometime and you can hear for yourself and yes I would do it again. Funny I was just talking to my buddy Mark today, the tech that did your inspection, about your car.
PM me if you would like to meet up sometime.
Walt
Walt
Is there a reason Porsche doesn't offer the pse option with the turbo?
The exhaust has a valve that opens in Sport Plus and the sound difference is noticeable, which as close as you can get to sports exhaust in a Turbo. Turbo charged engines will never sound like NA ones because all the beautiful explosive noises get muffled as they pass through the Turbos.
