Sponsored by: Road Spy
What did you do to your 991 turbo today?
Old 08-31-2020, 11:17 PM
  #1636
bigrpowr
bigrpowr's Avatar
Originally Posted by Steven31371
I drove it...vigorously
1.74 sixty foot...need to tweak the launch power to hook up a lil better...though that’s on the street with cool tires
on the street, its really hard to do much better. doing an awd burnout in sport+ helps for sure.
Steven31371 (08-31-2020)
Old 08-31-2020, 11:18 PM
  #1637
Steven31371
Steven31371's Avatar
Default Soooooo
Cloooose 😂😂😂
down and up a hill but still valid...tires were at 32 psi semi warm...had at 28 psi and got them to 32 before punching it...still spun a lot though but not as bad...
when you guys use LC do you floor the gas pedal or launch with it at 5500 rpm?
Old 09-01-2020, 12:16 AM
  #1638
onfireTTS
onfireTTS's Avatar
Received 1,119 Likes on 864 Posts
Cloooose 😂😂😂
On my much lower hp TTS, I can hold the brake and let it hit 5500rpm for 1-2 seconds and launch. You might have to watch the tack come up and leave sooner with the big power. Will take some test and tune time to find the sweet spot. Holding it at 5500 is probably building too much boost for the tires.
Old 09-01-2020, 01:16 AM
  #1639
BMS
Former Vendor
BMS's Avatar
Higher RPM is usually better for the larger turbos, lower RPM might make the car bog at launch. As stated, will need to play with it to find the sweet spot.
-Payam
Old 09-01-2020, 01:19 AM
  #1640
Steven31371
Randomly found the sweet spot on one 0 to 60 run and got a 2:24...need to find they again lol
Old 09-04-2020, 06:21 PM
  #1641
2fcknfst
2fcknfst's Avatar
Received 4,124 Likes on 3,121 Posts
I see you have added some stripes - they look pretty good.
Old 09-04-2020, 06:42 PM
  #1642
MotoJB
MotoJB's Avatar
Drove it to meet up with our Friday Supercar NorCal group...
The following 5 users liked this post by MotoJB:
Archille (09-07-2020), Big Swole (09-07-2020), pfbz (09-05-2020), r00t61 (09-05-2020), Redlinerobert (09-04-2020)
Old 09-04-2020, 11:36 PM
  #1643
Redlinerobert
Redlinerobert's Avatar
Very cool. Is that Kirby's GT3RS I see?
MotoJB (09-05-2020)
Old 09-05-2020, 01:34 AM
  #1644
MotoJB
MotoJB's Avatar
ITZKIRB all right!
Old 09-07-2020, 12:29 PM
  #1645
Big Swole
Big Swole's Avatar
Received 2,108 Likes on 1,328 Posts
Bump.
Old 09-07-2020, 06:45 PM
  #1646
Agentorange
Agentorange's Avatar
straight pipe the beast (Kline race pipes)
The following 2 users liked this post by Agentorange:
Big Swole (09-07-2020), Jean (09-16-2020)
Old 09-07-2020, 07:21 PM
  #1647
Masonbrick
Masonbrick's Avatar
I installed a front license plate mount. I ordered it through Carbonio. They didn't have a specific mount for a 991 Turbo, but they put one together for me from photos and measurements I sent back. I've had their mounts on other cars that is the reason I preferred them.
I had a tow hook mount on my old 991.1 Turbo S and I never liked the offset, as well as losing one of my parking sensors.
The following 2 users liked this post by Masonbrick:
Ditchhanger (09-13-2020), rbrotmd (09-07-2020)
Old 09-07-2020, 07:26 PM
  #1648
Masonbrick
Masonbrick's Avatar
I also installed wind deflectors from AWE. I had these on my old Turbo S, which I discovered I needed during my first HPDE when the wind buffeting was almost unbearable.
Big Swole (09-11-2020)
Old 09-13-2020, 01:16 AM
  #1649
skl
Official Wednesday AM Red Bull F1 test driver
skl's Avatar
Fixed an issue that had popped up a week ago that I thought was going to require a trip to the dealer. The airbag warning came on and at the same time the homelink quit working- seemed like too much of a coincidence. Also noted the little lights in the top light console weren't working. Tried to replace the fuse which immediately was fried. Also tried to clear the airbag warning with the Durametric and it came right back on. I had put in a "mirror tap" cord for the V1 a while ago which never seemed to be a problem but it too was dead. Popped out the console and pulled out the tap- fuse replaced everything worked and the airbag warning stayed off... somehow the tap must have wiggled together and shorted out. Won't bother with that again!!
And Durametric again to the rescue...
Old 09-13-2020, 03:13 AM
  #1650
osunick
osunick's Avatar
Consider getting posi-taps, much more user-friendly and can't guillotine the two wires together. Also, the penetration on the insulation is much smaller, just a pin hole. Easy to add additional wires to your tap too.
The following 2 users liked this post by osunick:
BMS (09-13-2020), Need4S (09-13-2020)
Quick Reply: What did you do to your 991 turbo today?
