Quick question-tool box contents
What comes in the 2015 GT3 tool kit? I have a wrench and screw driver in the plastic rectangular box. I also found a strange metallic bar in the trunk with square ends that resemble a ratchet. Just want to make sure that everything is there before the honeymoon is over with the dealership.
I looked in the manual and I can't find a description of the contents of the toolkit. Thus far, I have the screwdriver, wrench, and that other piece, which appears to be a drive device for a socket that is missing. I am also missing the small black wedge used to access the PDK cover.
Not in the tool box, but you should also have the center lock socket and plastic tool to remove the caps. This all can sometimes go missing. Replacement is $$'s
That looks like all that came with my car.
The plastic wedge type tool should be in the same foam carrier that has the tow fitting and "small" tool box. The center nut socket is located under the panel in the compartment that has the battery, Right in front of the brake master cylinder
Thanks guys...found the small wedge hidden down under the carpet, so I think everything is complete. My dealer said he will go through the car again to make sure everything is complete. He is a good guy...rare find these days.
