991 GT3, GT3RS, GT2RS and 911R 2012-2019
Who has taken their wing off to WRAP...?
Old 01-13-2016, 07:43 PM
inactiveuser7616
inactiveuser7616's Avatar
Default Who has taken their wing off to WRAP...?
Hello-
I'm working with my vinyl vendor to wrap my wing.
They haven't ever done a GT3 and are not sure how the end caps come off.
Two questions:
1. I believe the 3rd brake light connection is located behind the passenger tail light, correct?
2. How do the end caps come off? I'm told they are attached via clips and double-sided tape. I'm reluctant to simply 'yank' them off. Lol. Any insight, ideas, experiences, etc...are GREATLY appreciated.
Thank you.
Old 01-13-2016, 07:51 PM
1965356's Avatar
Don't do it. It's got too many sharp angles. Every one I saw wrapped was peeling no matter who did it
Old 01-13-2016, 11:11 PM
inactiveuser7616
Appreciate the suggestion and sharing your experience.
They did the main part already and I'm okay with the finished product.
Now trying to figure out the end caps.
inactiveuser7616
Anyone else.....?
Old 01-13-2016, 11:45 PM
16'991GT3
16'991GT3's Avatar
No clue, but are you going with yellow?
Old 01-14-2016, 12:01 AM
inactiveuser7616
You know it!
This is the rendering without the top stripes finished.
Old 01-14-2016, 12:02 AM
inactiveuser7616
Here are the stripes...
Old 01-14-2016, 12:28 AM
16'991GT3
16'991GT3's Avatar
wow looks great! I definitely like the black stripes over the yellow on the hood, can't wait to see how the wing turns out!
Old 01-14-2016, 01:01 AM
inactiveuser7616
Thanks bud! I really like how it's turning out!
Old 01-14-2016, 01:04 AM
Bags
Bags's Avatar
Default Rear Wing
Car looks great.
I also had my rear wing wrapped, great job no issues with pealing etc.
As I remember the electrical connection is under the deck lid on the right side. Disconnecting it, and removing the four bolts in the base the uprights, will allow you to take the wing off. The outer end caps do not come off without the potential for damage.
Old 01-14-2016, 01:13 AM
Detailed Designs
Detailed Designs's Avatar
To remove the spoiler, disconnect the light first from the underside of the engine lid. It is a quick connect that also has a difficult to remove clip that holds it in place.
Once the quick connect is disconnected, pop the 4 plastic caps off the uprights on the engine lid and then unscrew the mounting bolts. They are TORX heads.
When all connections to the body are free, use 2 people to slide the wing upwards. Once free, one person can support the spoiler while the other fishes the connector through the hole.
Not really advisable to remove the end caps, imho.
Old 01-14-2016, 02:17 AM
inactiveuser7616
Thanks guys!
Old 01-14-2016, 09:54 AM
odwa
odwa's Avatar
Phil, looking great!
Old 01-14-2016, 10:54 AM
inactiveuser7616
Thank you VERY much!
Can you advise on how the wire gets fed back through the hole?
Old 01-14-2016, 11:27 AM
Detailed Designs
It is obvious once it is removed. If they can't figure it out, tell them to stop and you want to come get your car immediately....it is that straight forward.
Quick Reply: Who has taken their wing off to WRAP...?
