Kobalts Great White RS
#391
7.28 BTG
Missed second apex at Flugplatz. Not good for the run down to Schwedencreutz but exciting.
Standing start which indicates a 7.27-7.26 is possible on flying lap.
#392
Great run! Now you only have to find ca. 30 seconds to be on par with factory Kobalt👍 I need to find ca. 21 sec to be on par with factory. I know I cut 10 easy, then it will be harder...
I never understand these Harry laps as they seems to end the lap far from gantry / end?
I know you drive with gps enchancer so it should keep track better i guess?
#393
I havn't checked the gps data but I'm guessing that there is a lag/synchonization problem with video.
I believe that for the Lap Timer to work it needs to have a corridor defined - not a line that is being crossed - to make the Lap Timer work when driving both slow and really fast. So depending so where in the corridor the Lap Timer detects where it is you might have a build in fault in your recording of data.
I haven't tried to tweak Harrys Lap Timer yet - maybe it is time to do that
Anyhow: The recorded length 18579 meters and average speed 149 kmph. It seems to pretty consistent with other laps in my Harrys Lap Timer.
And yes it was recorded using 20Hz Vbox so it is pretty accurate. I'm using Harrys BTG track. Of course there can be a misplaced trigger point at the gantry.
FWIW: Did a few runs and forgot to turn on the VBox. When using the internal GPS in the iPhone it does not detect going under the bridge on flying laps (I drive thru the corridor in shorter then 1 second).
#394
I guess this nice thread now could get in to winter - sleep mode. But lets go down 2017 in spring and make them laptime go down.
As I know it the Porsche 991 RS factory time on full lap (-T13) is 7.20min, and that translate to ca. 7min flat on the BTG lap, then thats factory speed more or less if One pull that of.
7.08min BTG is ca. factory speed in M4 GTS. (Ca. Same as 7.28 full factory lap.)
7.17min BTG translate to same laptime as sport auto drove M4 GTS(7.37 full lap -T 13)
Thats very likely I do in GTS, if more than my 4 laps. I am today 12 sec after that in just 4 laps. I make it happen in spring time for sure👍
7.08min BTG translate to same laptime as sport auto drove 991 GT3 RS(7.28 full lap - T 13)
(estimated ca. times)
#396
Its strange why this issue is on Harry, all video I seen got same issu more or less. If we see my vbox video it always cut time at gantry, hence Harry need to look in to that issu. It can not be hard to solve I guess. Still its been this way For years now in Harry wich is kind of strange?!
#397
Swedish
Congrats on the RS!
Congrats on the RS!
#400
Nice going!
#403
7.28 BTG
https://www.youtube.com/watch?v=uI307HyAf24
Would have loved to see your hands!
#405
