Battery Maintainer
#46
Of course, you are correct.
Now, just how do you know if your charger of choice is putting out AC ripple currents?
If you don't have a clip-on AC/DC current probe for your oscilloscope, how would you know?
Plus, $59.60 including 2-day shipping from Amazon doesn't seem extravagant to me: Amazon.com: CTEK (56-158) MULTI US 3300 12-Volt Battery Charger: Automotive
Enjoy your "ripple currents" LOL. I am sure you will sleep better.
#48
I wish I knew how Noco and Battery Tender were internally constructed. I'm an EE and have my own (possibly peculiar) ideas about what makes a good battery maintainer, or not.
1) Old school (i.e. Porsche wall-wart-style) battery maintainers were made by using a wall-voltage AC step-down transformer and a semiconductor rectifier circuit filtered by an electrolytic capacitor. This circuit performed just fine for as long as the crappy capacitor held its "capacity". Electrolytic capacitors sometimes "dry out" or otherwise lose their "capacity" to function over time or from power-line surge abuse.
2) After the capacitor lost some portion of its function, the 120 Hz (or 100 Hz depending on local power specs) rectified AC waveform caused ripple currents to appear in the charging current. It turns out that large values (you get to guess the critical amount) of ripple current cause all sorts of nasty chemical actions in the battery chemistry and the internal resistance of the cells begins to rise. After a sufficient amount of time of being charged in this high-ripple-current manner, the battery begins to resemble an anvil in its ability to hold a charge. Kaput!
3) I experienced many battery failures in my stored-for-the-winter vehicles during the time I was ignorant of the AC ripple-current battery destruction mechanism. I took "perfect" care of the batteries with impossible-to-know imperfect or failing battery maintainers. They seemed to charge the battery, but the battery failed anyway. I was really pissed.
4) The C-Tek method does not use a conventional transformer/rectifier that can output 120 Hz (or 100 Hz in Eu, etc) ripple currents if imperfectly reliable. C-Tek uses a 10's or 100's of KHz switching regulator that samples the incoming AC wall-plug voltage at this very high frequency and filters it with a small, but effective, inductor. This system cannot excite the same destructive chemical reaction if something goes slightly amiss. The inductor filter is much easier to guarantee its function over time and, if it failed, the frequency of operation is less molecularly active in the battery if the failure goes unnoticed. Ripple-current battery destruction is sooooo much less likely.
5) After changing to the C-Tek high-frequency switching-regulator battery maintainers, I have NEVER had a subsequent over-the-winter battery failure in any of my cars.
6) Anyone using anything BUT a C-Tek (or equivalent) battery maintainer is ignorant or a fool!
#50
Macca
I got what I was told the last weeks production car. Built in December 1997. I took delivery in January and sold it last fall. Nice profit. I guess I should have keep it. Then I ordered 2015 GT3. Should have keep the 1981, 1982, 1986 Turbo, 1989 Speedster. Instead sold them last fall and ordered a 918. All fun cars.
#53
Macca I got what I was told the last weeks production car. Built in December 1997. I took delivery in January and sold it last fall. Nice profit. I guess I should have keep it. Then I ordered 2015 GT3. Should have keep the 1981, 1982, 1986 Turbo, 1989 Speedster. Instead sold them last fall and ordered a 918. All fun cars.
#54
No I don't have a 918 on order. Was trying to say that if I keep all my previous Porsche's I could have sold them last fall and had the money to order a 918. They all went up. Way up. Enjoyed the heck out of them when I had them.
#55
Got my CTEK 3300 from Amazon. Plugged it in via cigarette lighter plug in the arm rest, easier access than the passenger foot well. Cord through the driverside window slightly open, then put the car cover back on. Selected snowflake mode and let her charge on. Easy. Thanks for everyone's suggestions. Saved a bunch of money not getting the "Porsche" branded one.
#56
I believe you will not the full benefit of the maintainer if the car is not in full "sleep" mode. Leaving a window open will keep the car awake. I believe it is better to run the wire down the door sill and just close the door. There is a rubber seal there that will just deform w/o causing any damage to the wire.
#57
I cut a slit on the rings that go onto the battery and slipped them onto the battery connectors on my 4S. Works great.
You can see some pictures here:
http://www.6speedonline.com/forums/9...-tender-2.html
#58
#59
Received 5,407 Likes
#60
I guess both of you guys could be correct. When I read the thread I thought the statement was leaving the door cracked rather than the window as clearly stated. The key is to set the alarm to maximize the charger benefit. IIRC the alarm system design is such that it will not fully set if certain parts of the car are not fully closed.
