G Forces
#31
Wow! Great to know that another device showed that much as well. My AIM SOLO showed 1.3-1.4 max but if I recall correctly, Orthojoe pointed out that AIM uses GPS unless calibrated and set in a different way, which I never did. Yes, the banking and back, I unfortunately know a lot about that too!
#32
Aim solo has an accurate internal accelerometer, but that needs to be calibrated every time you change the mounting position of the device. If you don't calibrate, it will be off. If you don't want to calibrate, the unit will also read Gs based on gps calculations, but that isn't as good as a calibrated internal accelerometer.
#34
I'm 99% certain that the electric emergency brake is a separate unit from the main service brakes. Tim has that great Technical Information book for the car. I'll bet it's shown in there....Tim?
Also, after reading about the pedal drop in Sam's car I went out, started mine up and tried releasing and setting the e-brake several times and could detect no change in the pedal position. I can't explain the discrepancy with what Sam experienced.
I've never tried the "****" feature, but one can't release the e-brake with the door open unless the service brake is depressed so the two are obviously related.
It is possible.
BTW: There is a separate fuse just for the e-brake button....
It is possible.
#35
I never photographed the g-force screen before I shipped the car from Europe (and the battery has likely since been disconnected) but I notes left had max g at around 1.47 (on the road).
As far as Im aware its not easily achievable to measure the temp of the tyre. The best you can do is look at each 1 bar as 10 celcius which IRCC is the technical correlation. I use the TPMS to simply tell me when my tyres are "warm" vs "cold" for spirited drives.
I dont think a tyre air temp reading would be much use at the track really. When we measure the tyre temp we use a pyrometer probe across three points (width of the tyre). It differs alot depending on camber and toe/castor. The temp of the air in the tyre and thus teh pressure are directly related but they say nothing about the contract patch and the temps across the tyres tread.
There is a formal delta between a rise in PSI and temperature. The TPMS is set to record nominal values at 20 Celcius according to the manual. Once you know this and your static readings you can quite easily calculate the temp. I.e. if 2.9 fronts = 20 C then 3.2 fronts are 50 C and 3.5 fronts are 80 C (and pretty darn hot). If I recall some autobahn type runs (200-280kmph) in the GT3 created front and rear temps around +50 C higher than nominal...
#36
I don't believe that these reading actually mean anything useful since they are only transient, but I noticed this after my track day at Laguna on Saturday. I'm betting the 1.81G is from the dip at the apex of T6. Cup2 tires.
![](http://s6.postimg.org/6wnjvq9a9/IMG_6209.jpg)
#39
Looks similar to mine. I think the elevation changes at Road Atlanta contribute to my high readings. Not sure what explains my higher braking force. Using PFC11s.
#42
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/d217220f_a700_4bc7_8702_7e01b29d01f7_1fe20e059da5306f918cdfcb449a0f10d5aaecd3.jpeg)
I never looked at the max (didn’t even know it was recording) until I found this thread.
My my first post btw, so let me introduce myself. I got a Chalk ‘18 Touring on Cup 2 tires 33psi front and 36psi rear when hot.
Im in Miami so my 2 go to tracks are Sebring and homestead.
These numbers are most probably from my last run at Sebring.
I’m surprised I got over 1G in acceleration (must be through a corner?)
Cheers
#43
^ I'd be interested to see some more updated .2 numbers
#44
