Possiblities?
#92
Paint.
Easy. Remove the plastic parts of the key carefully, if I recall correctly from the tapered end first then work your way to the other end. Then I use small prism like plastic parts to place the key parts on. One coat of primer then I waited 10-15 mins, then two coats of red (the OEM are NOT GR, so I found something a hair darker at Home Depot, assuming you want red) waiting 30 mins between each coat. 30 mins later, I did two coats of clear, also 30 min apart. I sprayed from 15-18 inch distance to apply a thin film and not to blow the key parts away. It will take forever to cure. Last year, when I painted one yellow (black TTS with yellow brakes, stitching), and inserted the key into the slot after a few days, the paint peeled off. I realized it wasn't cured. This time, I waited a month before I tried it.
#93
Now this conversation is getting awesome again, like the good old days. I thought about white then I decided to do red/black as it matched the interior better, since I have red/black inside and no white. Note the keychain with contrasted red stitching too...
#94
BMW gave 6/100 wrt oil lubricated parts on the M3's with bad rod bearings ('01-'03), which seemed sufficient to offset the public concern etc.
#95
Paint.
#96
And perhaps you wanted to mesmerise Mike in CA.
It worked, he's on his way to Home Depot, just not in his GT3...
#97
#98
#99
Thanks for the details, Sam.
#101
#102
BMW also started using the engine immediately in its factory racing programs with excellent reliability.
The S54 was hardly a run of the mill engine primarily used for normal highway driving and a 6/100 warranty to cover both engines
makes complete sense, especially considering most will hit the 6 years before 100K ie. it is really a practical 2 year extension to create value and confidence.
#103
#104
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
