991 GT3, GT3RS, GT2RS and 911R 2012-2019
No Slicks on 991 GT3!!
Old 09-18-2013 | 12:05 PM
  #106
85Gold's Avatar
85Gold
Originally Posted by wanna911
It must be really bad if they are all out saying no slicks. With the CL, they at least put their money where their mouth was and ran a CL version in the 24 hr race.
Slicks are ultra sensitive to toe changes and will blow out on you in a second. Now that I think about it, it's akin to an issue that myself along with several other 996 TT guys have had. Fine static alignment specs, but too low of a ride height on the 996 caused too much toe out under heavy loads. Slicks blew out within a day if not a session or two (Michelin, Hoosier, Yokohama). DOT slicks lasted much longer and treaded R-compounds life seemed almost normal, with a little toe tapering. Feasible RWS could cause a similar scenario and slicks blow out.
^ This I corded a set of R100 at the 2009 UTCC on the inside rear with less than 20 laps.
Peter
Old 09-18-2013 | 12:53 PM
  #107
modifier's Avatar
modifier
People are saying this was caused by center lock failure. Perhaps this has something to do with no slicks.
http://www.dpccars.com/car-videos-12...urburgring.htm
Old 09-18-2013 | 02:57 PM
  #108
kristob's Avatar
kristob
Don't go to dealer on slicks....
Old 09-18-2013 | 03:35 PM
  #109
frayed's Avatar
frayed
WHOA
Old 09-18-2013 | 04:03 PM
  #110
Bob Rouleau's Avatar
Bob Rouleau
Still plays with cars.
Two things which may help understand PAG's position:
1) GT3 centerlocks and hubs were recalled twice. The first was a non event, the nut was changed to eliminate the 500 NM stamp since PAG upped the torque spec.
The second was more involved and replaced hubs and other components with those used on the 997.2 RS which are more robust.
2) Owners of the .2 RS (like me) received a notice saying that hubs and bearings needed to be changed at intervals, 8,000 KM in back and 14,000 in front if driven on the track. In addition at around 25,000 KM the front uprights need to be changed. Since mine had 30,000 KMs on it, I followed the bulletin. Cost me $6,000!! Porsche's attitude is if you use it like a cup car, follow the same maintenance schedule.
Perhaps in an effort to avoid liability they've decided to ban slicks altogether.
Old 09-18-2013 | 04:20 PM
  #111
frayed's Avatar
frayed
This is my take as well.
I wouldn't run slicks anyway cause my car trailering days are over.
But if there is an issue with a subsystem, I'd like to know about it.
Old 09-18-2013 | 09:23 PM
  #112
modifier's Avatar
modifier
wrong info
Old 09-19-2013 | 12:11 AM
  #113
TRAKCAR's Avatar
TRAKCAR
Or buy a cup car and trailer.
I have neither at the moment.
Old 09-19-2013 | 12:29 AM
  #114
ShakeNBake's Avatar
ShakeNBake
there is a redonkulous trailer for sale right now in ads....small, but perfect.
Old 09-19-2013 | 03:54 AM
  #115
BBMGT3's Avatar
BBMGT3
I think "maintenance like a Cup Car" is not a bad thing actually. It largely depends on how fast you are going too. But drivers who are getting a lot out of the car will be tiring components out. So, $6,000 every 8,000km or so is actually very fair as that sounds like 2 seasons of track work. Put it in 24 hour terms - in a 24 hour race, a Cup car running a 2 min lap around a 5km track will complete 3,600km (much less in reality due to pitstops, but bear with me). So these parts are good for TWO 24 hour races or more. I suspect its a state of mind; 5 lugs are maintenance free. Almost, I change my wheel bolts once every other season. Come to think of it, thats about the same as specified for the CL. Just price tag is different.
Just my $0.02
Old 09-19-2013 | 07:05 AM
  #116
911rox's Avatar
911rox
Whilst I accept that the reasons for such a decision are all speculation for the moment, if in fact CLs are the reason for the ban of slicks, AP and his engineers will have **** on their faces considering they have avoided CL discussion like the plague with the launch of the new car, considering that they indicated bearings had been upgraded to Cup car parts, hubs/bolts had been strengthened and that there was no CL issue...
Old 09-19-2013 | 07:20 AM
  #117
Bill_C4S's Avatar
Bill_C4S
Originally Posted by BBMGT3
I have a strong suspicion its because the RWS can't handle the grip from a slick. The variable toe is electrically controlled...
if Nissan could engineer Godzilla to run RWS on a race car in 1992....on full slicks....then to not offer this capability 21 yrs later..suggests to me...as has been mooted in this thread...to risk/liability mitigation
Old 09-19-2013 | 07:27 AM
  #118
wurlie's Avatar
wurlie
Racing. Not posing.
Old 09-19-2013 | 04:23 PM
  #119
utkinpol's Avatar
utkinpol
wheel bearings, hubs and all links are the subject to be checked before each event, people who do not do that are insane.
but realistically a lot of people simply do not have a clear understanding to what degree they intensify load on front wheel bearings and what is a realistic life expectancy on those parts in track conditions on r-comps with close to 1g load.
and in my personal opinion those who own p-cars and still use CL system are plain crazy. all 99x race cars I see at my mechanic`s shop long time ago swapped all corners into 5 lugs.
Old 09-19-2013 | 08:22 PM
  #120
modifier's Avatar
modifier
You mean switching from center lock splined to center lock with 5 tapered lugs? Or to 5 lugs with nuts or 5 lug bolts? Or are you talking about something different?
Quick Reply: No Slicks on 991 GT3!!
