991 GT3, GT3RS, GT2RS and 911R 2012-2019
High milage .1 gt3 without engine failure
Old 08-03-2022, 01:28 PM
  #61
TinyPP
TinyPP's Avatar
Originally Posted by johnsopa
Seems like we're going to need a Google Sheets database!
(still hoping to win the lottery on my .1 GT3)
if a publicly viewable spreadsheet is started I would recommend adding the following:
  • Year of Manufacture
  • Original engine serial #
  • Replacement(s) engine serial #
  • Mileage
  • Track/No Track use
  • US vs International
  • Cam & FF catastrophic failure (Y/N)
  • Other
My thinking is that with enough data we maybe able to extract "unknown to us" but "known to porsche" the probability of failures based on the various FF suppliers where metallurgy based INCLUSION anomalies may exist.
Old 08-03-2022, 02:33 PM
  #62
TPG
TPG's Avatar
Originally Posted by jb997
Mine is G60942 we are not so far off :P Installed Jan 2021
in one year 413 engines.
​​​​​​​Like I posted above. My engine was replaced 1/22 G61355
Old 08-03-2022, 05:55 PM
  #63
BryanCO
BryanCO's Avatar
  • Mileage
  • Other
What's the probability of rod bearing failure in an BMW S65? From what I've read over the years (admittedly, I don't own a .1 and don't follow the issue extremely closely), the .1 issue is similar in the sense that its a design (material selection, tolerances, etc.) as opposed to a part defect (batch issue effecting a set of parts). Therefore all engines are at risk of failure and, hence would be expected to fail with the timing based on use conditions.
Old 08-03-2022, 09:33 PM
  #64
TinyPP
TinyPP's Avatar
I agree with your comments. Plentiful Data however is essential to an educated guess and deriving at a probability of failure. As an example, if someone's engine serial number happens to fall within a range of documented engine serial number failures, then one can postulate that the same FF's came from the same supplier and then decide to either ride at 9000 rpm's until the engine fails, sell the car or perform a Thelma & Louise.
Old 08-03-2022, 10:35 PM
  #65
rickster997
rickster997's Avatar
@Mthrice it looks like you've had a G6 for several years. Do you track it? If so, how many events in the last 2 years?
@Jickel180 seems like you have 3 years. Do you track it? events?
Old 08-04-2022, 10:09 AM
  #66
Jickel180
Jickel180's Avatar
Yep, I daily drive and track this car. I've racked up 20k street miles and 1700 track miles on the G6 alone. Only issue I've had with the G6 was a failed bank 2 cam position sensor at the track which ended my day early. Easy swap once the part arrived.
sbonomo (08-04-2022)
Old 08-04-2022, 12:38 PM
  #67
GT3_991.1
8th Gear
GT3_991.1's Avatar
My car had 28k kilometers on original 2014 engine before G6 replacement last winter
Old 08-04-2022, 01:49 PM
  #68
Dub911
Dub911's Avatar
I've owned three E92 M3's and personally I believe that the rod bearing issue is greatly exaggerated. I've been around many of these cars and spoken to several BMW techs about the problem and have yet to encounter anyone who has experienced it first hand. On the other hand, I think that the 991.1 issue is underrated and for most of the GT3s of this era its just a matter of when, not if.
slipaway37 (08-09-2022)
Old 08-04-2022, 02:24 PM
  #69
GT3_991.1
8th Gear
GT3_991.1's Avatar
I agree with you on GT3 part - I think every 3.8 engine that was not replaced with G is affected and entire case is underrated.
I do not agree on BMW though. I owned S54's, S65's and S85 (just one thank God!). I love M3's, but rod bearing issue is real. It all depends on use, and milage - and fair to say in S65 I replaced them in the nick of time. They were so worn, main bearings had to be checked (and yes changed too). Car had 100k miles - a lot of them heavy track use. 10w60 and always warmed before hard driving.
I noticed cars from warm climate do not suffer as much as those, that are going through cold starts in low temperatures. I experienced S85 bearing fail. Just change them every 100k kilometers.
ljmartyre (08-06-2022)
Old 08-04-2022, 03:29 PM
  #70
Mthrice
Mthrice's Avatar
9k miles and 8 track days. No problems at all, and .2’s don’t pull on me either.
Old 08-04-2022, 04:30 PM
  #71
rsbenfield
rsbenfield's Avatar
G60392 - replaced April 3, 2020. 7K miles, multiple track days, no issues.
Old 08-04-2022, 05:49 PM
  #72
sbonomo
sbonomo's Avatar
Hmmm, my engine was replaced in Dec 2016 - due to the local privacy laws i don't know exactly how many miles (i bought this used) it had. That would put mine squarely in the F-series right? Thank goodness i still have 2-years left on the warranty.
Old 08-05-2022, 10:54 PM
  #73
rickster997
Update. Got my car back today! Really missed driving and still miss driving at WOT! Already signed up for PBOC at Sebring in September. Need to break it in before then.
The following 3 users liked this post by rickster997:
itrsteve (08-06-2022), pjazz (08-07-2022), Rick GT3 (08-07-2022)
Old 08-08-2022, 04:20 PM
  #74
rickster997
Final update. Put it up on the lift to make sure the right engine was in there. It was. I'm good to go.
The following 2 users liked this post by rickster997:
BLKMamba (08-27-2022), jb997 (08-08-2022)
Old 08-09-2022, 04:19 PM
  #75
leozip
leozip's Avatar
Just bought a 2014 991.1 GT3 with 18k miles, apparently oem engine still. warranty on motor good until 07/24. I will try to have my tech check on the engine to make sure its the oem or revised version. So lets see what happens.
Quick Reply: High milage .1 gt3 without engine failure
