N Spec Michelins
Any issues with mixing tire spec front vs rear, example N spec Sport Cup 2s in front with M0 spec tires in rear?
I have 20x12 rims and have the option of mounting 305/30-20 on rear, learning that Michelin doesn't recommend for SC2s and is recommending 325/30-20. No N spec tire in this size, only M0.
TIA
TIA
TIA
TIA
"Spec" tires can have up to 5 or 6 different compounds laid up across the width of the treads, with varying combinations. Choose wisely.
![](https://rennlist.com/forums/attachments/981-forum/1324186d1631122933-porsche-n0-vs-normal-tires-spec-tire-differences.png)
AlexCeres (01-17-2022)
TIA
TIA
I can tell you the N0 in 305 is wider than the non-N0 in 305.
Not saying you can't run larger; but Porsche specifically developed the SC2 N1 in 305 for the GT3.
This is because the N0 and N1 305 isn't a 305, more like a 320 designed for the 12" wheel. Trust me any other 305 tire that isn't N spec will be stretched.
