Differential fluid
I want to change the diiff fluid in my GT3. I track the car and want to be proactive on maintenance. I have been told to use Mobilube PTX 75w90. When i look it up it is regular trans gear oil. Also any tips on changing the fluid.
Thank you for help. Tried to find past threads about it, to no avail.
I got this tip from @deilenberger. Remove the refill bolt before removing the drain bolt. It's easier to have a drive-able car instead of trying to fill fluid in a hole facing up. I also use a cheap hand pump to pump fluid in. You don't need something fancy here.
The transmission/differential is all one unit, same reservoir. I have a motive power fill that I use, makes it super easy to refill a manual transmission.
https://www.motiveproducts.com/colle...th-pinch-clamp
Which oil is recommended?
Thanks guys
Thanks guys
PDK wet clutches use automatic transmission fluid.
https://www.suncoastparts.com/produc...iABEgIu1PD_BwE
I had my PDK fluid changed by a Porsche dealer in November the cost was around $600 and if I remember correctly the fluid was about $250. I figured if anything goes wrong I wanted a PCar dealer invested. The price differential wasn't worth it to me.
I just did this...
Diff/Trans are same unit, there is one fill and 2 drain plugs.
I used Motul 8100 75-90 fluid, the car feels a little smoother, but also did the oil at the same time with Motul 8100.
On my 16 GT3, there was no fill plug, where the fill is there was a seal plug. Right next to it is a oil cooler fitting like 24mm aluminum through nut, that is where I filled mine.
There is not a lot of room for the bolt to go in and out, also getting a wrench in there.
Fluid came out pretty clean, and with only a little bit of smell. I think every 3 years is a good benchmark on changing it.
Here's a good thread on the 991 forum. The PDK clutches use the AFT fluid, the transmission/diff are like the manual and use the 75w90 gear oil.
https://rennlist.com/forums/991/1135...id-change.html
