Akraprovic Slip-On Center Muffler Opinions
Currently have the Sharkwerks CM bypass with valves pinned open on my '19 GT3- great sound but may be a bit too much for daily use (very slight drone, a little boomy). Recent drove a stock '19 GT3S- it wasn't much louder than the stock GT3 but I really liked the exhaust note. Just curious if anyone has heard or own the Akrapovic Slip-On Titanium Center Muffler (NOT bypass)- and how it compares to the stock GT3 / SW CMB / stock GT3RS? Thanks!
I have the Akra slip on installed in my RS, along with valved side deletes. Volume-wise, I think they’re on par with the stock RS center muffler, but has a tad of a higher pitch. Zero drone with this setup regardless of valve setting.
I have a set of Dundon catted headers sitting in my garage, waiting to be installed with the Akra slip on.
Basic Sponsor
Let us know if you would like a price on a set!
-Josh
-Josh
Your #1 Dealer for Aftermarket Performance Products
BC Forged / Soul Performance / Akrapovic / Bilstein / HRE / AL13 / CSF + more
Orange County, CA
Email: info@merakiautoworks.com
Text/Call: 213 394 2886
Website: www.MerakiAutoworks.com
Orange County, CA
I have a .2 GT3 with the akra center and it is 10% louder inside and 30% louder outside above 4k rpms. Its a great exhaust to DD if you want to loose the weight and have a little more sound.
Akra center was AMAZINGLY PERFECT on my Touring. Not too loud. Not too quiet. Just right. Just gives it that little bit of needed volume but only when you want it. Recently sold the car and will be selling center. If anyone's interested send me a DM.
why not try side deletes, keep the stock center, and dump the large side mufflers with valved side deletes. Sounds great, less transition from open and closed, has a much cleaner sound, not boomy or megaphone like. Then you can add headers in the future if you decide to.
Larry Cable (01-24-2024)
did u delete the sides ?
What is the best solution from Akrapovic for 991.2 gt3?
Important creteria:
- to have better sound, but not wild. It should be civilized but just better than stock (which is already a good one I must say)
- having no drone at all is extremely important
- so that the car maintains porsche warranty, so DME tune is not accepted and I am also not accepting any other complications
Important creteria:
Important creteria:
Important creteria:
I'd actually say that the primary motivator for me would be the weight reduction... which would lean towards a side replacement vs center
2019 GT3RS here. I have done a few Akrapovic options. First off I love the brand as product quality is the highest I have seen.
Centre bypass only - I did this first. I found this very subdued and only slightly louder than stock. Very refined, very smoothed out sound and not much burble. No drone.
Bypass plus link pipes - Wow big difference in volume, very loud especially in low RPM, lot of highway drone. The sound just started to give me a headache, that low bass sound would just carry. My neighbours could hear me blocks away. I needed another solution.
Evolution system- It includes Akrapovic Centre Bypass plus headers, hi flow cats with valved sides. Yes this is very expensive but I am happy with the results. Loud when it needs to be and a good rumble in low rpm and start up. With valves closed it is not too loud unless past 4k rpm.
Did it sound better than stock? Was the change really noticeable?
From what I read in your post, other options are no go for me.
no "cat back" solution should require ECU/DME reprogram ... also remember that many tracks have sound limits and pretty much any aftermarket exhaust will probably *blow* those out of the water - hell my GT3 OEM does not pass Laguna Seca sound ...
Weight reduction is of no interest to me
Love mine. It's just enough for me. Here is a cold start.
https://www.youtube.com/watch?v=mEu6QLqBD3Y
Yes correct. It is a center bypass. To me it's just right and enough for what it is and how Porsche does their exhaust. I do wish Porsche did their exhaust like Lamborghini does. I have the factory race exhaust on my Huracan. It has the most ferocious barking downshifts I've ever heard. It's just nuts in any RPM in corsa (race) mode. In strada (street) it's as quiet as a Toyota Camry and has no drone. Issue in the Porsche is their valves don't open until around 4k RPM. You can disconnect the lines at the bottom to bypass this. But I don't care for the droning and the sound. That's why I feel others have to do a lot more then center bypass to get around this.
is it buying and installing just this item?
https://www.akrapovic.com/en/car/pro...48&yearId=5458
is anything else needed in addition?
