Center lock mounted OK?
Originally Posted by LandShark
How do I do that? Do I need to unmount and mount again?
My local tire shop....
1). Tighten with wheels OFF the ground. Important. People have lost a wheel on track from not doing this.
2). Torque, unwind, and retorque
3). Reapply the optimoly paste to the mating surface off the wheel and nut face
4). Torque to the proper spec
5). Lock the mechanism (they clearly didn't)
The following 5 users liked this post by orthojoe:
MaxLTV (11-06-2019),
mdrums (11-06-2019),
pdxjim (11-05-2019),
Perimeter (11-06-2019),
slipaway37 (06-05-2023)
catdog2 (06-05-2023)
Just us a 1/2 inch breaker bar with pivoting head to turn the lock nut a little an it will pop right out. I use track wheels and can be changing them everyday. While that little tool works..eventually...but it can be a pain. The breaker bar nut fits pretty good and just needs a little turn or tap and out comes the lock.
after detailing.....
Found the same thing on 3 of my 4 wheels. Centerlock pins only engaged halfway out on three wheels. Stuck the tool into them, applied slight pressure on tool counterclockwise and they all popped out flush. I don’t think I’ll ever trust another soul after service, it’s just too easy to double check and do your self.
Completely agree. Remove you wheels and bring to tire shop. Ask for the most experienced tire installer. Remove the wheel weights yourself unless you want to risk scratches on the barrels !
What about on a factory car? Anybody ever find them unlocked on a car that's never had a tire change?
Um...if you're going to re-torque (which I do suggest), what difference would it make to pop the lock out first? It's going to get pushed right back in when you put the socket back on the center lock nut.
Or do you mean to pop it out first if you're going to be driving it back to the shop? Then, of course, do that.
Really? I find that surprising with the rubber ring and the friction from that seemingly keeping them in there pretty tight. Maybe they weren't pushed back flush, or the rubber ring was damaged? I've done a 5-7 track days a year without issue at speeds up to 155-160 mph. None have flown off yet.
