Road damage GT3 Touring
Thanks everyone -- I guess there is no suspension issue. Just an expensive repair to the wheel (just respraying the inside) and the brake caliper. I have my answer that they probably won't cover this issue under warranty.
Normal wear and tear. Not a warranty problem.
Just be thankful you didn't get a rock between the rotor & caliper or pads. Will score the PCCB rotor which is not cheap! And, they only sell them in pairs, so twice as expensive!!
yes those are normal, those are just to drive the sensor to level the head lights, also used for suspension compression measurements. But nothing wrong.
Originally Posted by 911 Flavors
)This is clearly a poor design (or poor manufacturing) -- not what I expect from our P cars.[/img]
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
That body crack where the rocks get stuck was the same for my 2015 GT3. I bought some black foam rubber stripping at Home Depot, cut to length, then used a plastic spatula to squeeze it in there.
It's just wear-and-tear. Accept and move on, or pay to repaint if that makes you happier.
This post almost makes me want another ADM thread. Almost.
Good this means you are driving AND enjoying your car
"black foam rubber stripping at Home Depot, cut to length, then used a plastic spatula to squeeze it in there"
TIA
