Light Weight Battery for .2 GT3???
#91
#94
Premium Sponsor
Also the battery you are recommending.... the least expensive and lightest Liteblox is only 7.5 REAL Ah that costs MORE than our RS-30 which has 30 Real Ah. But then we have the ATX12-HD-RS.... which would beat up on the Liteblox with 3 more REAL Ah, about 80 more Cranking Amps at 75% less cost and you can actually buy it NOW in the USA.... and if you didn't like it or had a warranty claim could call us and get it dealt with immediately. Liteblox, last I saw, didn't have a Distributor in the USA. Also the Bluetooth thing while cool sounding has an issue, but that is for another thread.
pride355 (05-03-2021)
#95
Premium Sponsor
They Cayenne's use the next size up which is the "H7" size... and some other P-Cars use this size also. But we will be making those too later.
So this first one we are making should cover the majority of the P-cars out there. And we can easily do other models once I know the sizes and type of mounting they have... but if Porsche has used that bottom mount over the years than that will be easy to make for other models that I'm not familiar with.
#96
Premium Sponsor
But also, as verified by the Porsche Tech where I bought my Car and whom has assisted me with all my questions about the PIWIS and other details of Porsche's in Car Battery Management there have been a few of over-discharge failures on that Lithium Battery that he personally saw. I want to state that this was told to me by the Tech at Porsche, and I have not verified that personally , but he also added he did not see that many bought, but that a few had come back and the customers were not happy because the battery was very expensive.
My closest experience with one was I was told by another GT3 RS owner that did buy the Porsche Lithium and that he had one for about 6 months and they could not get it to charge again after over-discharging and since his Dealer was good they just took it back and said they would take it up with Porsche. It would be great to hear from other Owners who might have opted for it.... but I can't really comment beyond that.
#97
Premium Sponsor
I will ask tonight about the Black.... I'm sure it just as easy as any other Anodized color so there should be no issues... they just started the milling so they have time before the Anodizing process and I will inquire. I know black Anodizing can sometime turn dark purple but that is in the sun. I also like that wrinkle looking stuff but I think that is more elaborate of a process... but it no harm for me to check.
#98
Would one need to lower the car a bit and get an alignment after reducing the front-end weight with a lighter battery? I guess it'd be prudent to measure the vehicle height before the swap and then after to make sure geometry hasn't changed too much.
#99
i was wondering the same, I’ve got a Porsche lithium battery from my .1 that I never even opened and undecided if to keep it for my .2 or sell it
#100
The loss of weight in the battery is much less than the difference between full and empty gas tank (about 150 lbs with extended tank) - wouldn't worry about it...
Having stiff springs means that 33 pounds makes almost no difference to ride height - it takes 514 pounds in the front of the car to drop the height an inch (each front coil is 257 lb/in).
#101
Oh yeah figure I might as well show you the mounting of the RS-30 Battery and a picture of my GT3 RS.... keep in mind this is the white plastic prototype I have been using in the car... but is shows better in the Picture anyway.... you will see the white plastic below the battery... excact fit of the bottom footer... just that one bolt holds it in place.
I live in Ojai CA and we have some great roads out my door, so very lucky...super green right now after a massive Nitrogen injection in the soil from the Ash from the fires in December... luckily I didn't have the RS back then...
#102
Having stiff springs means that 33 pounds makes almost no difference to ride height - it takes hundreds of pounds to drop the car an inch.
#104
Got spring rates here: https://rennlist.com/forums/991-gt3-...ing-rates.html
I assume spring rates refer to each coil and not the whole axle, but not certain...
#105
I just read that post and it is weird that he said it raised the car 1/4". By doing the math, it should take 128.5 pounds to make a 1/4" difference in ride height with two coil springs each rated at 257 lb/in. Not sure if OP may have mis-measured or what...
