Top center marker on steering wheel
#61
Amazon. Unfortunately it will cost you around $20.
#62
Thanks. It dies go well wuth the leather. I cut it to size.
Amazon. Unfortunately it will cost you around $20. http://www.amazon.com/3M-MATTE-Scotc...wrap+matte+red
#63
I just got regular sewing thread. You can experiment with different textures and diameters. It looks cool- kinda gives it a hand sewn effect. I'll rewrap it and post some high res pics.
#65
Sweet. I guess it's one of those DIY small projects that if it doesn't work or you don't like you can always try again or completely remove. Thank you.
#66
Originally Posted by awew911
Matte yellow 1080 wrap in the RS. The sample pieces that are available are sufficient in length to go around the wheel. No need to purchase a whole sheet.
#67
#69
#70
Any color you want, Mike...
http://www.metrorestyling.com/3M-108...ap-s/16524.htm
$1.00 samples. + shipping.
BTW - The Matte Gray Aluminum matches the gray wheels...
#71
Originally Posted by Mike in CA
Alex, where did you find the samples in red. Got a link?
#73
So a couple of quick questions, awew911. I assume the bonding agent is self contained on the material. Is there a peel off backing or similar or is it just pressure sensitive? Once bonded to the wheel, and in case I don't like the look for some reason, how difficult is it to get off?
#74
Thanks guys. I was too dense to find them on my own....
When I apply it, I just pull it a little tight to make sure it goes into the grooves. I use one of these to make sure it's in there nice and snug...
#75
So I tried out the 1/2" red gaffers tape and am reasonably pleased with the result. It took a few attempts to get the length and technique just right but with 60 yards of tape, I certainly had enough to experiment with!
I wrapped from back to front so that the overlapping tape seam would end up underneath the wheel rim and pointing away from the driver. One wrap seemed adequate and made it easier to tuck the edges of the tape into the seam. I used a sharp edged plastic upholstery trim tool to do that but honestly a fingernail would probably work pretty well.
It would look more professional if one didn't have to cover the stitching but there's really no way around that. I'll live with this for a while, or at least until the 3M 1080 vinyl trim sample that awew911 suggested shows up and then I may play with that. But for now, this is a pretty decent $10 mod.
