Options You Wish You Ordered......
#61
Joe -
5 gals are $41. Lasts 2 sessions. I bought 5 gals twice and then one 3 gals. Went to the Chevron in Willows on the way home.
#62
The manual on the Cayman recommends 93-octane - same as the RS. The difference is that the Cayman manual shows 90-octane as the minimum, the RS shows 91-octane. I can't find fuel higher than 91 (other than the 100-octane race gas) in Kali - actually anywhere west of San Antonio. Based on this, I would expect the computer to recognize and use the higher octane (at least up to the 93 number).
With the RS, I use a ratio of 1 gallon of 100-octane to just less than 3 gallons of 91-octane. With that car, the difference is quite noticeable, even on the street.
Now that my throttle issue is resolved (separate post), I'll try the same ratio with the Cayman.
#64
As for the RS, I picked it up in Houston in July (2009). It was 100+ degrees all the way into LA. Once I lost 93-octane, somewhere in West Texas (it existed in San Antonio, but was extinct at my fuel stop prior to El Paso), the car ran completely differently, noticeably down on power/torque, and less responsive. I also got a hint of ping at one point.
That car now has SharkWerks DME in it (tuned for 91-octane, not 93, which makes a couple more HP). I did it to remove the eGas delay as much as possible.
When I spoke with Alex, I'm pretty sure he said that the DME (even stock) will take advantage of up to 95-octane).
Running pure 100-octane seems to make no difference on that car (before or after DME). I think (honest) 93-octane, if it's available, would be fine for daily driving. If I take that car to the track on a hot day, I'll run a 50-50 mix of 100:91 just to be sure.
My big worry on these car, where the manual states 93-octane, is the stations that aren't really providing 91-octane. I got a terrible tank of 91-octane gas from a Chevron station in Morro Bay on the way up to Monterey, last year.
I'll let you know what I notice on the Cayman, but I'll be surprised if I notice anything while we're in the 60-70 degree range.
