X pipe advice?
X pipe advice?
Hello fellow financial mistake (my affectionate nickname for my car) owners! So I've been looking at after market exhausts and uh... can't really afford them since I'm a 17 year old who got very lucky and found a beyond reasonably priced example of a cayman S. Any advice on exhaust is welcome, but specifically I'd like to ask about x pipes. I guess OEM is a T pipe? I don't have the PSE system so I'd like to do something to make it sound a bit better and maybe increase the volume just a bit. What difference would an x pipe make here? It changes sound from what I've seen, but does it increase volume at all (not obnoxiously but just noticeably)? Does anyone run a Soul X pipe by itself, and if so could I get a video for comparison purposes? Also, I know that this is down to personal preference but on a midnight blue car would I be better off going with a grey or black metal? I'd assume I would want to color coordinate with my wheels but I don't know. Pics below
Last edited by KevinThe987; 01-04-2022 at 11:56 AM. Reason: Not sure if it matters, but is an S
Have you tried gapping the top crossover pipe yet? If you look up under the bumper you can see where the top crossover pipe has a sleeve joiner. If you undo the bolts you can slide the sleeve over to expose the gap between the two parts of the system. Thats cheap method for more noise
Cheers,
Julian.
Cheers,
Julian.
Cheers,
Julian.
Cheers,
Julian.
Thanks Julian, I have not! Might have to try that. Is it raw sound though? I'd like to stay classy if possible. Classy is a bit opinionated, I guess what I'm saying is I don't want to sound like a straight piped Honda Civic. Nothing against that at all of course, just not my thing! Also my other draw to a replacement pipe is the look. I definitely prefer dual exhaust as opposed to the what I've heard described as snout that comes OEM. Im willing to spend a bit, just not $2000 at the moment.
Ok awesome! I know little about exhaust, sorry! Currently researching. I'll definitely try this then, have you ever had a tip fall off though? I'd imagine as long as you tighten it enough it wouldn't be an issue, right?
You leave the outlet "T" in place and tight, it the upper crossover you loosen and slide over.
you can see it in this photo, on my car I was able to do this without removing the bumper or anything
I'm not sure that's a great idea. You don't want exhaust coming out under the car, you can potentially get fumes and carbon monoxide sucked forward that way.
X-tip would potentially change the tone a bit but wouldn't make a huge difference. Given that they're like $3-400 just for the tips you'd probably be better off saving up and putting the money towards a full exhaust.
thanks,
rowan
Well, Suncoast Parts has the PSE new but it's $3400 For used you'd probably have to check eBay or the classifieds. Keep in mind that you'll also need to get the button to activate it, and also probably get it coded by a dealer.
I don't know what you could possibly do to make that sweet Flat6 sing like a Civic. Or put another way, I don't think I have ever heard a Flat6 sound anything but glorious, unless I couldn't hear it at all, OR someone really did a hack to one.
So you are on a budget but you want the P-symphony for your sweet new to you ride? I suggest Carnewal it!
It's the poor man's PSE (without the valve)
Edit:
https://youtu.be/Y58AUyeK2uw
Edit:
The following 2 users liked this post by Snakebit:
KevinThe987 (01-04-2022),
KrisA (01-04-2022)
Oh boy, yeah I definitely would want a used one then. My thought was wire it to the sport button, seems like it'd be simple enough. Then again would I need an ECU tune for that? Maybe it'd be more complicated than I thought.
Agreed on Snakebit's comment on the Carnewal mod, best sound for the $ plus should save a bit of weight as he totally guts the inside of the cans.
If you want a dual tip on a budget I'd post a WTB add for either a Soul, Fabspeed or 987.2 S pipe. According to Gert Carnewal the stock 987.2 S pipe flows better than the cast x-pipes sold by Soul and others, if that matters to you.
Edit:
Edit:
