What did you do with your 987 today?
#1681
Finally cooler weather, took the 987.2 BS out early into the cool canyons. It is a near perfect car.
50 miles of empty twisty roads in 70º weather was splendid.
I see no need to upgrade or sell ever.
The following 8 users liked this post by scootr:
Carfan1 (09-02-2024),
Dave in Chicago (09-01-2024),
Flyrod (09-03-2024),
Jonathan_987 (09-01-2024),
mspalacios (09-19-2024),
and 3 others liked this post.
#1682
I just got my very basic base 2011 Boxster a few weeks ago, and I've been addressing a few minor cosmetic issues as a way to familiarize myself with this perfectly wonderful automobile. My last little job (I accomplished it on 8/31/24, actually) was de-bugging my right taillight. And my that I mean that I removed the dead bug from inside the light assembly.
Unwanted, unaesthetic insect stowaway, prior to removal.
#1684
Interested in this - want to add a bike rack! Whats the hitch spec if you dont mind sharing?
#1685
Looks like one for sale here for $450USD shipped. No affiliation and not much more than what I paid, comes with a hinge as well. Looking at it again the main plate looks different than mine, looks like receiver sits lower. Mine looked more like this one.
The following 3 users liked this post by old man neri:
#1687
The following 2 users liked this post by Zach L:
916Carl (09-25-2024),
porsche_rrr (09-05-2024)
#1688
@Zach L Hey. I looked at your pictures to help me with the install. I didn't run the wire through the bumper like you did cause I wasn't sure how you did it. Mine is just going to through the rear hatch. I am using a Curt 59187 but if I were to do it again I would go with the Curt 56189 as I didn't use the 'power wiring kit'. Instead I just used a fuse tap. I also used my open wire taps. I haven't used it yet but I've had good experience with that converter on my wife's car and I've used another one of their converters when I had to flat tow a car across a couple provinces with no issue.
#1689
Which version of the head unit did you get? I see there are a lot of versions listed.
Did you create a post on your installation? Or is there an earlier post showing the installation that helped you the most?
Thanks!
Thanks!
#1690
No post really helped me that much for the install. I just found a quick youtube on how to remove the trim and old unit, slid the new one in, and that was that. I didn't install any periferals (GPS antenna, back up camera, sim card reader..etc). All I use the unit is for Android Auto. I don't really use any of the native/internal functions. I may, in the future, install a back up camera. I think I have a spare one kicking around. Running the wire might get tricky though.
GreggZ (09-09-2024)
#1691
Installed a Soul Performance Cat-back Exhaust which significantly improved throatiness and a much more aggressive tone overall. I can now distinctly hear pops and crackles when decelerating. Glorious. Saved 15lbs too.
Installed a SprintBooster V3 and this feels like a totally new car with the increased throttle response on Sports mode. Crazy on Race mode. Heel-toe and rev-matching has to be re-learned given how different the accelerator behaves.
Installed a reverse camera installed on the OEM license plate lens, wired and interfaced to PCCM+.
Very happy.
Very happy.
The following 3 users liked this post by mspalacios:
#1692
Re: multiple sources of support when under the car....... pucks on order... and will look at 2nd form of support. When on 4 jack stands, where would you place the jack so you can still access the oil area? Any good suggestions or plans for 4 wood platforms for the tires or other reasonably priced solution?
#1693
I leave my jack under the back as a 2nd form of support when on the jack stands. Saw the suggestion in a YouTube video.
I have not done much work under there, changed oil, spark plugs, coils, but the jack staying in place was easy to work around.
mspalacios (09-16-2024)
