After Market Camera Install Question
For those of you who routed an aftermarket rear camera to a JoyeAuto/Isudar/Mr12Volt unit, how did you run the wire through the bumper into the trunk?
I ended up with the Mr 12volt box stashed in the drivers side footwell.
Received 4,087 Likes
I ran the wire into the bumper through the license plate light hole. Worked well. I used the left light because the camera wire is short and that's the side my camera wire comes out of my frame.
There's a very active thread and the aftermarket head units in the 997 forum.
Here's a few videos:
FrostyNorth (06-17-2024)
As I recall, I drilled a hole tight above the license plate for the camera to mount to. Removed the right tail light. There is a gap within that cavity where you can get a "fish" wire in with a reasonably direct path to the hole drilled for the camera. Poke the fish wire through, & attach the the end of the camera wire to it. Gently pull until the camera wire is in the cavity.
I just bought the JoyeAuto CarPlay kit for my CDR 3.1 but have not yet installed it. I wanted to install a backup camera and maybe a front camera but did not want to do any drilling for the cameras. I plan to use one of the cameras that just replaces one of the tag lights so it just snaps in. It has its own LED built in. I had one of those installed on my 350Z and loved it. Camera resolution is as good as my wife's Subaru or my Bronco Sport and they are fairly cheap. To attach the front camera, I planned to use the 3M Dual Lock tape. That stuff is awesome and much stronger than Velcro or double sided tape..
Here's a thread that may be helpful. I removed both my front and rear bumpers to install the cameras so they look OE. There are pictures of them in the linked thread.
https://rennlist.com/forums/gt4-spyd...in-my-gt4.html
Thanks for all the replies with links! Helpful aggregation of information.
I am planning to use a cam that snaps in to replace one of the license plate lights. I’d like to avoid drilling it possible.
