968 Forum 1992-1995
Anyone know where this bolt goes? Pics included.
Old 11-23-2016, 08:21 PM
touareg
touareg's Avatar
Default Anyone know where this bolt goes? Pics included.
Trying to figure out where this bolt goes, may fix the other problem too...
Old 11-23-2016, 08:23 PM
RajDatta
RajDatta's Avatar
Looks to be from the water pump. It's a m6 bolt?
You are a lucky man that your bs belt didn't completely sheer off and take the timing belt with it.
Old 11-23-2016, 08:28 PM
touareg
touareg's Avatar
Thanks, I need to get my house built so I can get a garage, do my own work and not deal with mechanics that do stuff like this. So ticked right now as this could have been a very expensive fix if that washer was a little bigger and ripped through the belt.
I wonder if all that belt dust is going to get into anything and cause havoc on rollers, or of a good blast of air will be sufficient to clean it out.
What is the book rate in hours (which is what I am sure I paid) for a full job (water pump, coolant, rollers and belts). I had other work done and plan to ask for all the labor plus any new parts I need to get. I just plan to pay the 600 or so dollars for the belts, rollers, gaskets and water pump effectively.
Old 11-23-2016, 09:04 PM
RajDatta
RajDatta's Avatar
There is a lot of fiberglass in those belts and it is some nasty stuff. I would not touch any of that with bare hands or you will be itching for days.
I would have to check on labor hrs for the job but it would have to be in the 6 HR range.
Old 11-23-2016, 09:09 PM
touareg
touareg's Avatar
Thanks I appreciate it Raj! I was guessing 8.
I am also suspicious of a waterpump being installed in my car for a few months having that much rust on the impeller pully already?
Old 11-23-2016, 10:05 PM
V2Rocket
Rainman
V2Rocket's Avatar
I'm guessing it's one of the 2 long bolts that hold the rear belt cover to the oil pump, down either side of the crank pulley.
Old 11-23-2016, 11:50 PM
touareg
touareg's Avatar
That would make more sense, putting the rear cover back on, belts, got distracted and left the bold there accidentally. I had to be placed, I can't see a bolt falling there.
Old 11-24-2016, 02:37 PM
RajDatta
RajDatta's Avatar
I wouldn't think it would be either of those. That was one of my thought as well but when you think about it, those bolts are too long to actually be able to make their way out with the front cover on.
The water pump sits much further in, in comparison to the bolts you mention, which sit flush with the rear belt cover.
Easiest way to know is to measure the length of the bolt. That would easily verify exactly which bolt it is.
Old 11-24-2016, 04:49 PM
sm
sm's Avatar
Which shop did the work for you?
Old 11-24-2016, 08:40 PM
968workaholic
968workaholic's Avatar
Looking at your second pic, the view from underneath, look at the belt gaurd that wraps around the crank pulley for the balance belt. Its hard to tell in your pic, but it doesn't appear that the bolt that holds the piece on is there
Old 11-24-2016, 08:47 PM
968workaholic
Old 11-24-2016, 09:02 PM
968workaholic
Number 26 in below diagram
Old 11-25-2016, 09:19 AM
kwikt
kwikt's Avatar
I agree ^^^^^ had this bolt out many times.
Old 11-25-2016, 12:58 PM
RajDatta
RajDatta's Avatar
#26 is not a fully threaded bolt if I remember correctly. The bolt that holds the rear belt cover is a fully threaded bolt though. My bet is on the lower rear belt cover bolt if its not a waterpump bolt. A simple measurement would put all this to rest.
Old 11-25-2016, 03:00 PM
968workaholic
The 968 have a threaded spacer between the balance belt guide and the oil pump, unlike the 944. Item #9 in below diagram. Agreed though a measurement of the bolt length would narrow down its proper location
Quick Reply: Anyone know where this bolt goes? Pics included.
