Time to replace brake pads - recommendations?
Looking for recommendations. Primarily street driving with autocross once in a great while. Low dust would be ideal.
Hugo
Hugo
I cant recommend a pad compound but Jason at paragon products has an extensive assortment.
notes
if you are replacing the vibration isolators, I found it easier to mount the pads then slip the loaded caliper over the rotor.
internally, the stock rotors have a small ridge between the vanes but the coated sebro rotors did not on the non m030 style. maybe a little bit more heat dissipating mass
notes
I'm also planning on replacing pads. Anyone know about Porterfield r4-s pads? They were recommended for low brake dust and good braking efficiency, even when cool,
I didn't care much for the Porterfield R4S pads. Felt they were lacking in bite. Really liked the Porterfield R4 which stopped faster but dusty and noisey. Now I have Stoptech which I think work well in both worlds for the price. JMO
http://www.paragon-products.com/Pors...351.939.03.htm
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
Hugo
