Selling my 968
Sad day here. Just listed my 968 for sale. If anyone is interested, please reach me at the craigslist ad or at sscarpen@yahoo.com
http://phoenix.craigslist.org/nph/cto/5309540608.html
I realize the Craigslist ad was flagged. Here is a link to the new one:
http://phoenix.craigslist.org/nph/cto/5309973710.html
Also, here is the ad copy in case it gets flagged again:
1994 Porsche 968
Up for sale, due to a baby on the way, is my beautiful 968 coupe. For those of you unfamiliar, the 968 is a rare but highly coveted P-Car that has a cult-like status among its followers. There were only 2400 coupes delivered to North America from 1992-1995.
This is a fantastic one as well- it is the desirable late 94 build (6-speed manual transmission), with upgraded seats, and an LSD!! These are the most desirable features out of all the 968’s.
Manual transmission, power windows, power locks, keyless entry, power sunroof, power seats, leather, custom navigation unit with Bluetooth, custom hidden subwoofer and amp, upgraded speakers, custom exhaust, chipped and tuned, new paint job (was red, now metallic gunmetal gray), new tires and wheels, and a boatload of extremely fresh maintenance.
The first owner had the car for just 2 years, the second owner had it for 14 years, and I’ve had it as my daily driver for nearly 6 years.
Mechanically, this car is unbelievable. I’ve always done everything that is needed and on time, and have always done the little things (replacing dash light bulbs, etc).
Many recent larger jobs have been done- including clutch, clutch line, water pump, timing belts, engine seals, alternator, battery, tires. You are good to go for a long time!
I have a complete table of all maintenance done (I can email this to you), and stacks of receipts to back it all up. I have all records since 1996! I doubt you can find another Porsche with that documentation. Under my ownership, it was exclusively maintained by PORSCHE ONLY Stuttgart Southwest in Tempe, AZ.
The good:
Rare care with the most desirable options. Own something that draws tons of attention and questions. Tasteful upgrades to modernize the car (custom nav, keyless entry, upgraded sound system). One of the best maintained 968’s you can find. The big $$ maintenance items were fixed on my dime, and your belts tires, water pump, alternator, engine seals, and battery are brand new.
The bad:
While the body is fantastic and the paint is new and is very good (it wasn’t a cheap paint job), but it isn’t 100% perfect either. If you are a 100% purist, you may not like the color change or upgrades. One of the fog lights was recently cracked.
The deal:
It seems like last year I cringed at other guys giving up their cars because they were having kids, and somehow it’s just happened to me. But I will NOT get a minivan!
I’m very sad to see her go, but it’s the right thing to do. My time is pretty valuable, and I’m in no rush to sell, so any offers must be able to be backed up with cash, and I won’t entertain anything unreasonable either. If you aren’t truly interested or don’t have the cash, please be respectful of my time. If this ad is still up, the car is for sale.
This will be a 100% cash deal, I cannot finance or trade.
VIN WP0AA2967RS820582
Date Odometer Reading Approx Mileage DESCRIPTION
3/31/94 117 117 Jonathan L. bought car in Nanuet, NY
7/12/96 19,025 19,025 Stephen S. bought car at 19,025 miles
7/22/96 Alpine CD changer installed
8/12/96 19,763 19,763 Eprom Chip and Tune
Carbon Fiber Power Flow Intake installed
Installed Complete Stainless Tri-Flow Exhaust System (B&B)
2 New Tires
5/13/97 43,982 43,982 45k PORSCHE SERVICE TO MANUFACT SPEC
Removed and replaced timing, balance, acc'y belts
Sent B&B muffler for repair
Refinished fuel filler door
6/02/97 44,730 44,730 Replaced power steering o rings
Replaced rear wiper
1000 mile retension of belts
6/05/97 44,862 44,862 Replaced sunroof gears
7/23/97 51,064 51,064 Oil change
Windshield Wipers
Adjust front wheel bearings
2/09/98 51,064 51,064 60k PORSCHE SERVICE TO MANUFACT SPEC
Replaced front brake pads, discs, sensors, repack wheel bearings
New clutch disk sport, clutch release bearing, c2 turbo pressure plate, dual mass flywheel
4 new tires, repaired windshield washers, k&n filter charger kit, complete detail
5/05/99 67,467 67,467 Replaced radiator fan switch, fan fuse
Fixed exhaust rattle
10/05/99 70,932 70,932 Replaced balance shaft belt and tensioning roller.
Oil change
1/21/00 72,665 72,665 Belt Retention
Repair exhaust heat shield
7/21/00 75,789 75,789 75k PORSCHE SERVICE TO MANUFACT SPEC
Corrected balance shaft timing
Clutch Master and slave cylinder serviced
New improved muffler from B&B installed
Complete detail
6/1/01 75,000 75,000 Replaced hatch motor
5/30/03 New gas cap
6/15/07 81,505 81,505 FULL SERVICE (belts checked, fluids, battery, lube, brakes, exhaust, clutch)
New tires + wheel alignment
5/22/09 83,000 83,000 Replaced front and rear shocks, Koni sport cartridge fitment
1/16/10 Scott C purchased car from Rumson, NJ
1/25/10 84,091 84,091 New exhaust clamp
2/2/10 Complete detail
3/2/10 85,603 85,603 Swapped control unit for airbag fault
Oil change
3/15/10 Custom Installation Navigation and Remote Entry at Autowerks. No receipt
4/1/10 Miguel Window Tint (30% all around) 602-576-3322. No receipt
87,546 87,546 Oil change
Fixed high pressure oil leak
Fixed sun roof gears
5/26/10 Installed new battery from Autozone
88,199 88,199 Odometer stopped working. Started mileage log on Nav Unit
6/10/10 88,199 88, 240 Repaired hood light switch (draw problem)
Topped off A/C (odo wrong on receipt- didn't tell shop about it)
9/1/10 88,199 92,600 90k PORSCHE SERVICE MANUFACT SPEC
Spark plugs, all new OEM belts, all idlers and tensioners, air/fuel filter, flush cooling system
10/4/10 88,199 93,900 1k belt adjustment
11/29/10 88,199 96,120 Oil Change, Fixed rattle in door handle, lube clutch pedal
3/9/11 88,199 99,671 Replaced Clutch and Pilot Bearing, Fly Seal, Crank Seal, R-Rear A Arm Bushing, Oil Change
5/27/11 88,199 103,644 Oil change, replaced bad DME relay, replaced clutch master cylinder, brake fluid and hose, replaced starter, replaced clutch slave cylinder, bleed system
7/5/11 Purchased spare DME Relay and hatch struts from autohausaz
~ 8/1/11 Replaced clutch line (missing receipt)
10/20/11 New Sumitomo HRZIII tires (front), balanced
10/20/11 New front brake pads, front-end alignment
11/09/11 88,199 108,644 Oil change, replaced rear hatch struts
2/2/12 New Sumitomo HRZIII tires (rear), balanced
3/24/12 88,199 113,644 Oil change, check fluid levels
5/01/12 Purchased customer cubby subwoofer and box
5/31/12 Professional install of sub, + Alpine amp
7/26/12 88,199 118,644 Oil and filter change, new air filter, replace inner RF inner sway bar bushing
10/6/12 Replaced battery (prorated amt)
11/20/12 Replaced windshield
1/15/13 88,199 121,644 Replaced Door Mech and Lock, Oil Change, Repair Exhaust Rattle, fix P/S leak
5/18/13 88,199 123,600 Replaced cam belt/tensioners/pulleys, timing belt/tensioners/pulleys, idlers, lubed clutch linkage and poss.
7/4/13 88,199 124,800 1k belt adjustment. Replaced alternator
10/25/13 88,199 126,800 Oil change
88,199 Paint job and body work- didn't drive car from 12/4/14 to 8/8/14
8/8/14 88,199 127,500 Repair Odometer and Dash Lights, Reseal Cam Cover, Replace Spark Plugs, Misc Body Work
10/28/14 90,874 130,175 Fix Oil Leak, Degrease, Oil Change, replace hood struts
12/19/14 Complete detail
01/02/15 92,667 131,968 Degrease, r&r pump and lower belt shaft, front seal housing (r&r blles, etc,) reseal oil filter housing gaskets, tube o rings
Bought Jeep Unlimited. Didn’t drive car from 3/10/15 - now
11/09/15 Replaced Water Pump, adjusted all belts, installed new battery
Fixed Sunroof
Bmw, Mercedes, jaguar, roadster, z3, z4, cayman, 944, 911, 928, 924, carrera, spyder, s2000, 350z, 370z, sl
1994 Porsche 968
The good:
The bad:
The deal:
2 New Tires
Replaced rear wiper
Windshield Wipers
Oil change
Complete detail
5/30/03 New gas cap
Oil change
Fixed Sunroof
Why not post a price ? Couldn't hurt to become a RL member and get more interest by posting on the For Sale section ...
I was wondering why it wouldn't let me post of classifieds.
I have it up for $13,900 on CL (you know how it goes when dealing with people on CL), definitely willing to let it go for less to any RL or 968 fan.
There is no price in the CL ad right now, I know when I search CL I use a price range to avoid unpriced items. I feel if no price is listed that means it's too damn high. Just my opinion.
What color was it originally?
4 factory options on the car:
LT partial leather in black
XD4 painted crest center caps
220 Limitied slip
398 17" cup2 wheels
My first ad was flagged, and missed putting in the price 2nd time around. Fixed now.
I have it on Craiglist for $13,900obo- because you know how C-list can be.
Price is definitely flexible for enthusiasts.
