Wheel Arch Sticker Removal
Hi John,
Thank you for sharing the PDF. This does help alot specifically the installation section. I'll go ahead and give it a shot this weekend and show some before and after pics. So it looks like the windex/watery soap solution with the squeege option is not really necessary based off of the article. Did you try that approach and got the same results as just applying the peel and stick method? My bigest concern is getting any bubbles in there if I try the squeege method and not being able to get them out with the squeege.
Thanks ahead of time!
Calguy,
'80 924 N/A
'92 968 Cabriolet
Calguy,
'80 924 N/A
'92 968 Cabriolet
OkRider
Calguy, the blade lab guys at my work, to avoid getting air bubbles use a piece of aluminum instead of a soft plastic spreader. The aluminum piece is best described as the shape of a wooden stir stick or paint paddle handle. About the same size but about 3 inches long 1/8 inch and very smooth radius where it will be in contact with the tape.
They will cut a piece of tape about 8' long, remove the tape backing as they apply the tape to the leading edge of the blade. Then the tape is worked from the center to the edges in about 2-3 inch sections. The aluminum tool is nothing special at all but you can direct a little more pressure to the tape.
I think you could scuff the tape if you got too carried away, but I think you would stretch the tape first. I'm not saying all this is the right way or the only way, just the way at my work.
Doug
Doug
When you purchase the factory pieces you will find they are at least twice the thickness of the standard clear-bra. Because of this they don't tend to hold bubbles as the lubrication is easier to work to the sides. I used a decal application solution that I had purchased at an autobody supply store.
Jeff
Jeff
judge - if you are suggesting that dental tape could be used to remove the 20 year old factory protector, I would respectfully respond (and I think everyone else who has performed this procedure will agree) - near (if not completely) impossible. Or have I misunderstood your post?
judge - awesome! I would never have dreamed it, at least not with the dental tape I've held in my hands, but that's cool. Questions.
What brand or type of dental tape?
Were your protectors original?
What solvent did you use?
How much time per side to remove?
I obviously didn't use your method, and can't conceive of how it would have worked on mine, but I have another set to do........
judge's method does sound like it would have been an equally (if not better) route to take. The method that I used was that which was described by Cliff on the first page of the posting. It worked well. The only deviation in the removal process was instead of using brake cleaner I used 3M's General Purpose Adhessive Remover, which is amazing stuff to remove stickers etc without damaging the paint surface. I used this solution once before to remove the bonding agent off the car's body left from the old seal on the rear hatch of my 924. It worked great, the only set back is that it has a strong ordor and I would strongly recommend to use outside or in a well ventilated area.
Other than that the whole process went like this:
1) Warm the area with a hair dryer
2) Spray the 3M General Purpose Adhessive Remover
3) Use the plastic scoop #368 which I had no problem finding at OSH (Orchard Supply & Hardware)
4) Repeat starting from step 1.
The whole process took about 2 hours to remove one side and the end result was that the surface looks like new (I'll snap some photos this weekend and post of the end result, I don't think I have any before photos, but when I was peeling off the old sticker I did notice that it was yellowish, hardly noticeable on the car since the car color is black).
The next endeavor is to use the responses posted on this thread to install the new stoneguard clear replacements that I bought from the dealer (I'm hoping to do that this weekend, time permitting).
Cheers,
Calguy
'80 924 N/A
'92 968 Cabriolet
Cheers,
Calguy
'80 924 N/A
'92 968 Cabriolet
Calguy,
Congrats on getting the job done. One question on your approach, why would you spray the adhesive remover on the decal BEFORE it was removed? That stuff only works on the adhesive that under the decal. The decal is so thick and strong, I doubt it would do any good until after you remove the top piece and the adhesive is exposed. At least, that is what I have found.
Jeff
Jeff
You can use windex. That is what window tinters use and I have used it to put on door jamb sills as well as the chip guard film. It allows you to move the film around and when potioned correctly scrape out air bubbles and then let sit without touching or driving till all dry.
