968 Forum 1992-1995
View Poll Results: would you like to see the 993 and 997 style hybrid body panels (page 12, 13) copied ?
yes, would like to see lightweight copies sold by GT Racing or other vendor.
76
61.29%
sounds cool, but not interested in doing this type of update.
48
38.71%
Voters: 124. You may not vote on this poll
a few upgrades for the 968....
Old 12-06-2017, 08:42 PM
  #541
Amber Gramps
Amber Gramps's Avatar
How do you say Renntits in English?
Old 12-17-2017, 01:46 PM
  #542
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
Old 12-17-2017, 02:47 PM
  #543
odurandina
Team Owner
odurandina's Avatar
In the time after swapping to the high output pump, the problem of too much switched current, re; the ignition switching on the combined [computer + fuel pump circuit] eventually stressed the electrical box to the point of internal arcing and subsequent relay failure.... the result, (a common problem with early Chevy efi systems), produces a result quite similar to our DME relay issues.... I went about searching the internet and found where to check for a burnt relay... opened the computer hatch and found the suspect relay was clearly 'burnt'.... The events that brought this discovery proved yet again, that a good amateur mechanic like Doug Bray can keep this beast running indefinitely.... i didn't want to go near it, but Doug went straight to work......
By re-routing the fuel pump circuit and simply running a pigtail off the ignition wire into a new, dedicated relay box, and by changing the oem 14 (or 16) gauge wire to #10 wire, the high amps/high heat running on 1 circuit is now distributed to 2 low amps/low heat circuits.... Now my computer is running cool, and with plenty of juice.... With about 4 hous of work, Doug ascended to legend status... because not only do i have a perfectly running engine with just the single turn of the key, but this relatively easy upgrade can be done for the 944/968's running the oem engines. .... re; no more DME relay issues.....
Old 12-22-2017, 03:14 PM
  #544
odurandina
Team Owner
odurandina's Avatar
"i need a car, Bob.... i need a car......."
https://youtu.be/vayVEcfv3nM?t=680
Old 02-07-2018, 04:37 PM
  #545
odurandina
Team Owner
odurandina's Avatar
Old 02-13-2018, 07:31 PM
  #546
dougs968
OkRider
dougs968's Avatar
Originally Posted by odurandina
I can't easily express how amazing it is to have the perfect gear from 3rd to 6th running these tall ratios,
and the short stroke LS7 engine running @ full power.
back roads.... spirited driving on the twisties whatever the speeds...... Pacific Coast Highway.... freeway driving.... and steep mountain grades!!
sublime!
once you experience it, there's no way having 944/T gearbox combo running the tall 5th will suffice......
just not enough performance there.....
to cap it off.... look at that final ratio (last pic)!!
Oh, WOW!!!!
Old 02-13-2018, 07:34 PM
  #547
dougs968
OkRider
dougs968's Avatar
sublime!
And THIS!!! ^^^^^^
Old 04-09-2018, 12:28 AM
  #548
odurandina
Team Owner
odurandina's Avatar
Las Virgines Road, Las Virgines Canyon, Malibu, CA in full bloom....
Old 04-09-2018, 02:32 AM
  #549
odurandina
Team Owner
odurandina's Avatar
Sunset Blvd, West Hollywood, CA
o
Old 04-09-2018, 07:29 PM
  #550
jsheiry
jsheiry's Avatar
Sweet pics OD. Will you be back east in time for Hershey? Love to see that monster!. Could you get that full size spare in the well with some carpet mods?? Cut a little hole in the carpet and build a CF roof over the hole!!
Old 04-09-2018, 10:27 PM
  #551
odurandina
Team Owner
odurandina's Avatar
Originally Posted by jsheiry
Sweet pics OD.
should have got a real camera a long time ago.
i drive through Hershey often. Never in April. Maybe some day. ....Car ​​​​​is at Lart's Cut, Chop, Sawzall 'n Ship getting back breaking Koni stuff so i can tear up my ball joints, tie rod ends, etc on whatever you call that sorry excuse for an interstate between LA and Boston. Probably cheaper just to ship the car home. .....i drive the 968 trillions of miles on a stock suspension because it's the only way to not destroy everything else. Better to sacrifice sets of stock shocks and caster blocks every 15-20 k miles,
Old 04-09-2018, 10:38 PM
  #552
odurandina
Team Owner
odurandina's Avatar
Car ​​​​​is at Lart's Cut, Chop, Sawzall 'n Ship getting back breaking Koni stuff....
Oh SHlT!! maybe i should be posting a poll on the Turbz forum entitled, "will he pardd it?"
*i had a $5,000 Minelab GPX machine miraculously disappear from the care of some people in San Bernadino County last month.....
with my luck........
Old 04-27-2018, 07:39 PM
  #553
odurandina
Team Owner
odurandina's Avatar
Cool
Lart installed a fresh set of adjustable Koni's.....
much improved ride for desert crusing......
Old 04-27-2018, 09:10 PM
  #554
Boeing 717
Registered User
Boeing 717's Avatar
Which ones did you buy?
Old 04-28-2018, 02:51 PM
  #555
odurandina
Team Owner
odurandina's Avatar
The ones Lart told me go on the car.
Quick Reply: a few upgrades for the 968....
