How do you get the rotor off?
Go down to your local Sears and get one of these: http://www.sears.com/shc/s/p_10153_1...1&blockType=G1 .
It's a hand held driver that you whack with a hammer. The hammer blow both seats the bit into the screw and turns it out.
The way I did it, for what that's worth, I used PB penetrating oil letting it work for at least 5 mins. Then used a little heat from my MAPP torch and the longest philips head I had for the most torque. I also tapped the screw driver with a hammer and it broke free. The impact drivers as described above will work as well. To get the rotor off make sure the ebrake is off and I also tapped it with a blunt small sledge hammer.
Hope this helps
Hope this helps
Yeah before you get into using any tools other than a normal Phillips driver, soak the screw in PB Blaster, and in my experience it continues to penetrate and loosen beyond the first few minutes, badly stuck things often benefit from an hour or more of soaking (I once had to soak something overnight, but that was an E-Type torsion bar with 40 years of corrosion).
Once that's out, you SHOULD be able to man it off. If not, I hear they've got a 2-for-1 deal on ********* at Sears.
Actually I think the most effective way to get wheels off of rotors, rotors off of hubs, etc, when they don't want to come off, is hitting alternate sides of the face with some kind of hammer (rubber in the case of wheels, maybe sledge in the case of rotors) because the rocking motion exploits leverage to get it off one edge at a time.
