Gas smell - leak fixed. w/pics
Similar to Mike's post I had a leak that started out as a slight gas smell when I put the top down. Eventually it got worse and turned into a visible leak. I started in the trunk checking (like the parallel post stated) the filler neck and the tank points. Nothing was found there so under the car I went.
With the wheel off it was easy to see tha the leak was somewhere inside the lower tray that houses the pump.
To remove the tray you unbolt the retaining strap and remove a few screws and it lowers down with some twisting and coaching. With the tray off I found the leak easily. The banjo bolt (or whatever it's called) the holds the pressure fitting onto the pump was hand tight - WOW that was close, I could only imagine what might of happened if I had not looked inot the leak untill later-
I inspected the brass washers and re-torqued the bolt. Reassembled and all is fine. simple fix for a preplexing problem. Hope this helps- Cheers, Mike
Thanks for this. It's hard enough to figure these things out, let alone take pics of when you actually jump in there to figure out what the problem is and fix it. Well done!
Good job. It seems like a lot of cabs have this fuel smell problem. My car has this and I have not tracked it down yet. It is not very bad, but your post gives me motavation to take another look.
My dad used to complain about poor fuel economy in his F-150, turned out a fuel line was rubbing against a steel bracket, and it cut right into the line. It was leaking a few inches away from the exhaust... gotta love Ford. But aside from that it's been a good truck.
