Vac hose routing
There are two vacuum lines coming from the cabin into the engine bay (below the battery). I'm assuming that these are for the heating and cooling controls, does anyone know the routing?
Sorry for the delay but here it is:
Red line-->splitter-->blue check valve-->heater control valve
Blue line-->splitter-->Fuel pressure regulator-->intake manifold
Hope that helps.
Raj
Hope that helps.
Raj
Just what I was looking for ( I think). Is this the blue check valve that is located on the firewall (engine side)? Mine is split (which I guess is not good for heater control nor for vacuum) but I have not been able to locate it in the PET. From the blue check valve it goes through the firewall and connects to a black round "thing" in the battery compartment, next to the horn. Does this make sense, and would anybody have a part number for this? (has VDO written on it)
Never mind, just looked at the line to the HCV, and it was cut behind the cam belt cover, so I guess a need to seriously check the vacuum lines.., I guess this could explain some slight hesitation on acceleration I had been noting??
KTS
KTS
