More pics of 968s
#317
Apparently the original owner ordered the car with the 'comfort' seats - which I received with the car. After a short time he decided he wanted buckets, but as you say they are not the original type, there are definitely Recaros and look like the Profi model.
They're quite narrow, I could do with another couple of inches in width to be honest !!
#318
vacuumnoise (07-02-2021)
#321
TechArt Automobildesign
The Tuning-Program for Porsche 968 and Convertible
Body / Aerodynamics
TechArt front spoiler, for assembly at stock bumper, ABS material.
TechArt rear spoiler for convertible, for assembly on trunk lid, PU-foam.
Chassis
TechArt spring-kit, 2 sports springs for front axle, lowers ride height approx. 35 mm in combination with standard shock absorbers. Height adjustment for rear axle.
Light Alloy Wheels
TechArt Fittipaldi 17 Inch, 5-spoke wheel, 3-piece, star and outside well polished. FA 8,5Jx17 with tires 225/45 ZR 17 RA 9Jx17 with tires 255/40 ZR 17
TechArt Mito 3 18 Inch, 5-spoke wheel, modular, star and outside well polished FA 8,0Jx18 with tires 225/40 ZR 18 RA 9,5Jx18 with tires 255/35 ZR 18
TechArt Formula, 5-spoke HighTech-wheel, 1-piece, silver. FA 8,5Jx18 with tires 225/40 ZR 18, RA 10.5Jx18 with tires 265/35 ZR 18
TechArt Performance, 6-spoke wheel, 1-piece, silver or chromium-plated. FA 8,0Jx18 with tires 225/40 ZR 18 HA 9,5Jx18 with tires 255/35 ZR 18
TechArt Performance Racing, 6-spoke wheel, 1-piece, silky-black with coloured ring and TechArt Racing lettering with size indication. FA 8,0Jx18 with tires 225/40 ZR 18 RA 9,5Jx18 with tires 255/35 ZR 18
TechArt wheel-locks
TechArt valve caps in aluminium with logo
Spacers
TechArt wheel spacer set 18 mm, aluminium elox, 10-hole version with bolts and nuts, fits for Porsche original rims.
Exhaust-Systems
TechArt sports exhaust system, two-piece, black chromium tail-pipe 80 x 120 mm.
Interior
All leatherwork is hand-crafted to perfection in the own TechArt saddlery by experienced saddlers and upholsterers.
The use of only the very best materials and our vast experience guarantees optimal results. We can work on single parts, a complete interior, repair or restoration - the choice is yours, but your car is in the best hands at TechArt!
TechArt process leather in all standard colours and optionally offer a wide range of special colours.
These parts can be covered with leather of your choice:
Dashboard top side
Defroster slot
Air vents of dashboard
Cover panels for air vents
Air vent, center of dashboard
Panel for A/C and heating control unit
Turn signal lever and wiper lever
Instruments rings
Switchboard panel and instruments panel
Switch aperture / dashboard
Switchboard-cover and instrument panel
Control buttons for lights, fog-lights etc.
Control buttons for interval wiping system and dashboard lighting control
Button for filler-cap operating
Operating unit for time adjustment
Rosette for ignition lock
Ignition key / remote control for central lock
Dashboard lower part
Steering column casing
Steering wheel rim of airbag-steering-wheel
Airbag cover
Center console
Gear shift lever and shift lever cover (manual gearbox)
Gear shift lever and switch box (Tiptronic)
Hand brake lever
Tray shelf of center console
Door panels complete
Door panels middle parts
Door handles and cover for door pockets
Upper door trims
Handles inside for door opener
Power window switches
Rosettes for alarm system lamps
Control unit for side mirrors adjustment
Cover panels for door key strips
Loudspeaker frames, grilles painted on request
Rear side panels
Rear door key strips
Lock pillar
Side panel covers for door entrances
Backwall top section
Headlining
Sunvisors
Windshield frame
Softtop inside cover
Tarpaulin for soft top
Seats front with or without pipings
Seats rear with or without pipings
Backrest apertures
Switches for electrical seat adjustment including frame
Backrest release
Seat heating switch
Belt-keys and wips front and rear
Rosettes and covers for the safety belts
Original floormats with leather edges
All parts can be upholstered on a single base.
Optionally there are available the following TechArt Full-Leather Appointments:
TechArt Leather Interior Version I, completion of the ex-works available partial leather appointment with leather in all standard colours including dashboard upper and lower sections, instruments panels and dashboard panel cover, steering column housing, center console, gear shift lever **** with shift lever cover, hand brake lever, complete door panel covers including door trim, door handles and covers of door pockets, complete rear side panels including trims, rear luggage sherf, seat back parts front, emergency seat bench, sunvisors, lock pillar and windshield frame.
TechArt Leather Interior Version II, completion of the ex-works available full leather appointment with leather in all standard colours including instruments panel, dashboard panel cover, steering column housing, cover center console (below gear-shift-lever), tray / tape-box, door opener, A-cross tie cover, window frame (only convertible) and sunvisors.
TechArt CS-Interior for 968 CS, with: TechArt sports-steering-wheel, 35 cm in CS-Design, (2 colours, grip zones in suede leather), dashboard panels painted in body colour, gear-shift-lever-bellows in leather, sports-seats upholstered with leather in two colours (perforated seat faces, CS-logo), floor-mats with leather pipings and CS-logo.
TechArt Interior Extras
TechArt floor-mats with logo in all colours
TechArt carpet equipment in all colours
TechArt trunk carpet
TechArt sports-steering-wheels in different versions
TechArt sports seats in different versions
TechArt pedals in perforated aluminium for manual gearbox and Tiptronic
TechArt foot-rest in perforated aluminium
TechArt 4-point or 6-point safety belt systems, belts in red, blue, yellow, black, violet.
TechArt safety roll bar, steel, assembly at original belt points
TechArt instrument dials in different colours
Mobile Phones and Navigation Systems
TechArt telephone systems in different versions
TechArt telephone console, upholstered in leather/carpet, with or without integrated free-hand operation speaker.
TechArt telephone receiver covers in precious wood, genuine leather or chrome
TechArt cover for telephone unit in luggage compartment
#327
Many cars were equiped with 17" wheels at the dealer. Dealer installed 17 "Cup 1" wheels on my '95 Coupe before selling it to the original owner.
Ufnavy06 (06-18-2023)
#330
Damian,
Recall that while completing the North American 968 coupe registry I found there were TWO 1993 Speed Yellow M030 coupes produced and sent to Canada. They were twins. Since they were 93s they must have had the Cup1s. There is a few CarFax records out there for them. maybe turned into Race cars?
Jeff
