968 Forum 1992-1995
Rumble/Throb/Squeal From Front Brakes
Old 04-12-2007, 03:56 PM
DAKDAK
8th Gear
DAKDAK's Avatar
Default Rumble/Throb/Squeal From Front Brakes
For about 6 months the car was making a rumbling/grinding noise from the front end whenever I applied the brakes at low speed. It became more severe over time, and was inconsistent. If the brakes were cold (first 10 miles of driving in the morning) there would be no noise at all. I gave it to my trusty local mech (Pete's Foreign Otto in Valdosta, GA, top notch). He replaced pads and rotors all 4 wheels. Now the front right squeals like a Mack truck at medium to light brake pressure (again-inconsistent) and the rumble/grind has turned into a throbbing noise/feel through the brake pedal at high speed hard braking and a much reduced rumble/grind at low speed hard braking. It sounds like there is one point on the rotor that is sqeaking if I roll very slow, because it will "SQUEAK roll roll roll SQUEAK roll roll roll SQUEAK" you get the idea. I definitely am suspecting something worse than a rotor/pad problem. Any ideas out there?
'94 Coupe 6spd 87k miles
Old 04-12-2007, 04:28 PM
RajDatta
RajDatta's Avatar
Yeah, maybe your heatshield is slightly bent. Also, your rotor could be out of round or not installed correctly for it to only squeal when it hits a particular spot. What kind of pads are you using? When your mechanic did the brakes, did he check the pistons to make sure that they were moving freely and not binding anywhere?
Also, do you have plate lift on top of the calipers?
Raj
Old 04-12-2007, 05:01 PM
Damian in NJ
Damian in NJ's Avatar
Tell us about your car, you're new here.
Old 04-12-2007, 06:27 PM
DAKDAK
8th Gear
DAKDAK's Avatar
This car is bone stock with the exception of 17" 2-piece turbo-cup wheels installed in 2001. I've owned it since 1999/30,000 miles. Street car only. I don't really work on it myself much. I'm going home now, so I get to listen to my grinding squealing brakes again...I'm supposed to see Pete in the morning.
Old 04-13-2007, 04:30 AM
Lord_Galva
Lord_Galva's Avatar
Your car sounds like mine. When I put new Zimmerman rotors on my car, I spun the disk before puting the caliper on a noticed a slight wobble. Which now creates a squeak at low speeds.
Old 04-13-2007, 11:10 AM
RajDatta
RajDatta's Avatar
A lot of people that stock rotors make the mistake of standing them on their side. That is a big no no!. You will warp your brand new rotor. The rotors must be placed flat for storage. I have a feeling the rotors are warped even though they might be new.
Raj
Old 04-13-2007, 01:20 PM
DAKDAK
8th Gear
DAKDAK's Avatar
I took the right front wheel off yesterday and spun the rotor by hand, definitely a dragging spot. This from a brand new rotor... I also noticed that the strut dust cover was rotted away and pieces of it were loose inside the spring, AND that the foam head at top of the strut is cracked and coming apart. Could my "brake noise" be from front struts that need to be replaced?
Old 04-13-2007, 03:09 PM
RajDatta
RajDatta's Avatar
The foam head on top is no biggie. Its just there to lower some vibrations. That is common but there should be no play inthe strut. Looks like you have multiple problems, wrapped rotor and rotted/bent heat shield.
Raj
Old 04-14-2007, 04:32 AM
Lord_Galva
Lord_Galva's Avatar
Dang thanks alot Raj. Super informative. Should I worry that the disk is slightly warped? I probably will be replacing them next year anyway. (My mechanic suggested that)
Old 04-14-2007, 11:43 AM
Clem
Clem's Avatar
How does a piece of steel get warped standing on it's side?
Old 04-14-2007, 11:48 AM
RajDatta
RajDatta's Avatar
Because of its own weight . Ask anyone who handles rotors, they will always tell you to sit them flat on on their sides. My Dad was in auto retail business all his life .
Raj
Old 04-14-2007, 11:54 AM
Clem
Clem's Avatar
I find that kind of amazing, but maybe they do.
Sounds like a couple problems going on to potentially cause the noise. Raj asked earlier, but what kind of brake pads are you using?
If they are stock I would not expect them to squeal. Other compounds definitely could/would however.
Old 04-14-2007, 02:30 PM
Lord_Galva
Lord_Galva's Avatar
I'm using PBR ceramic. During the first week they didn't make a peep. After the wobble set in they now sqeek at 5-15mph.
Old 04-16-2007, 08:24 AM
DAKDAK
8th Gear
DAKDAK's Avatar
Stock pads. I'm going to have Pete replace the questionable rotor. Also going to spluge for new shocks all around, they are original. I'll keep this thread alive until I fix the noise.
Old 04-16-2007, 01:30 PM
Lord_Galva
Lord_Galva's Avatar
Switch to Koni shocks. I just did and they are awsome. They do require some minor surgury before installation but they feel great plus they are adjustable. Your only choices for shocks that I've seen(if you don't have the M030) are stock shocks ($300)each, Koni's ($160)each, or Blistin coil-overs ($1500)each.
Quick Reply: Rumble/Throb/Squeal From Front Brakes
