Gear Shift Knob Vibration
Same goes for the rear linkage. Is the bolt that holds the linkage to the rod the correct part? I have seen people use just a standard bolt and that wont do it, it needs to have a pointy tip to it.
I would start with shifter and go from there.
Raj
Unfortunately, I don't know whether you can replace just the broken part(s) or if you'll need the entire shifter (comes with a leather boot).
Good luck.
http://forums.rennlist.com/upload/dsc00010_copy8.jpg
the part number for the side bushings is 999.924.002.40 (you need 2)
the trick is pretty simple really - after removing the shifter (and i am not talking about the shift **** and boot, but the shifter itself) using a really heavy grease (not something light like white lithium), dab a glob of it on the ball of the shifter, and a bit in the cup of the new bushing (this is to act like more of a shock absorber than a lubricant) then set the ball into the new bushing, setting that on top of a phone book or block of wood - push straight down hard and smooth - if that fails to seat the ball, you can tap on it with a rubber mallet - do not use a hammer - take care on how hard you hit it - bottoming out hard will crack the new bushing - i did that twice before figuring out the trick
I thought first it might be caused because of problems in fuel delivery, so I maintaned the injectors, plugs, and lambda). the engine now revs better, and more torque + hp gained (closer to original numbers I guess), which has made me more happy with the great car and engine, but the gear shift know shake is still there. The gear shift know isn't really a problem, but in low constant speeds the car feels to "jerk" abit, which is annoying.
I think it has something to do with worn engine / transmission mounts, which I will get checked in few weeks.
1. is there any other suggestions from where this not smooth running might be caused, if not engine / transmission mounts?
2. What kind of mounts should I start searching for, which would be best? or are originals good enough? I'm using car generally for street use, but would like to find the best equip. available, to make most of my porsche.
and, happy christmastime for everybody!!
Here in finland we got snow eventually.. sometimes this greenhouse effect is annoying, the snow we usually got here comes later and later..
Your balance shaft belt could have jumped a couple teeth.
Stick to factory mounts or else you will waste your $$.
Raj
