HELP : VARIOCAM WILL NOT OPEN
My variocam will not open.
Any thoughts or experience with this problem ?
what plug ?
Thanks,
Gregg
Thanks,
Gregg
There is a plug on top of the valve cover which plugs into the variocam unit. Its pretty much in the middle of the valve cover. Make sure its plugged in. What makes you think your variocam does not work?
Raj
Raj
It did not open on the Dyno run.
All help is appreciated.
Thanks,
Gregg
Thanks,
Gregg
Where doues the wire run ?
Thanks,
Gregg
Thanks,
Gregg
There is a plug on the back of the valve cover,looks like a 1" round trailer plug. #'s 5,6,7,1 across the top with female connectors and 4,3,2 across the bottom. Male connectors.
What does this plug do ?
No, this is a rectangular plug. I hope someone with a 968 can post a picture to show you the plug. This plug is part of the engine harness and plugs into the solenoid that sticks out of the middle of the valve cover.
Raj
Raj
