Keep the 951S or get a 968??
Regards.
Raj
Raj
Jim
Raj
951's, easy to get decent power on with minimal money, and are cheap to get into, relative to a 968. If you want to do track events tho, I'd suggest that you not get power mad, as 300rwhp puts you at a point where I feel you will overpower the suspension/tires on a "streetable" car set up and you will wind up with slower lap times and MUCH poorer driving skills, especially if you are just getting started doing track events. If you are planning on track only monster, this would be the car to get, you can get the wide body set up and put a suspension on the car that will make you a true 911/Viper eater and get the hp to match, just open the wallet VERY wide.
Same could be said for most cars tho... 968's have the balance and poise that make it a better track car, in my opinion. Limited upgrades tho, and M030 cars with LSD are very rare, and a decent 968 will set you back more money. Also, there are a couple of potential areas of concern that need to be monitored (cam chain tensioner, in particular) or you could have a major $ repair on your hands. Its an easier car to be competitive with, given the SCCA/PCA class restcrictions, if you care about such things.
If you already have a 951S, I think its a foregone conclusion that you should keep it. Boost IS addictive, and you already know the car, so you should have few surprises. If you want to go to the track, I'd suggest hanging out with your local PCA DE'ers, there will be several guys in that group running 951's and they should be able to get you started down the right path. As much as I like Rennlist, I'd be very leary of the advise you get on the main boards, as most of those guys do not have real track experience and think that HP is everything. Trust me, its not. Driver skill is what you need.
As for the 928, it exudes a lot more "Porscheness" and is in a category by itself, at least as far as engine sound goes (I LOVE the rumble...). As noted, its a heavier car and feels HUGE compared to a 951/968, altho the weight really isn't *that* much more. Its a wider car tho, and that makes the polar moments a bit more extreme under real hard braking/cornering, but a 928 in the right hands is still a very capable track car. The only classes I think its competitive in would be unlimited classes (you really need to ask some of the guys campaigning 928s), and again, open your wallet wide. 928's tend to be pretty finicky as far as maintenance goes (driveline is pretty solid, but the little things will drive you crazy!) and they are a LOT more expensive to get parts for than a 951. My 928 (my wife's, actually) has the competition Bilstein struts, upgraded sway bars and a LSD diff in the automatic tranny, and is a BLAST to drive, especially in corners. My 951 will eat it alive, tho, in all categories except "Porscheness".
Regards,
I think 600 lbs. is a whole lot more than just "that". An '86 951 is 2899 (factory specs), 928 GTS is 3594 lbs. Big difference!!! It's like having 3 men at 200lbs. each driving with you!!
Regards,
