How screwed am I?
When I was putting my 968 away for the winter, the 1/2 inch wrench I use for the negative battery terminal ran away.
Or more precisely, I placed it on the "flat" plastic piece right next to the battery, toward the front. Well it slipped under the fender lip.
I have put it out of my mind until now. If I remove the black plastic engine surround should I be able to get at it? Could it slip down the wheel well liner?
Can I just drive it any hope that it works its way out? Only a $5 wrench? Still a few months away, just trying to get prepared for the inevitable.
-Yogii
AKA 968 Novice
PS My garage space is very cramped and dark.
-Yogii
AKA 968 Novice
Not sure precisely where you mean as my battery is in the rear boot. But, if it's fallen down enough can you access or fumble around for it from underneath - if you remove the engine undertray?
Are you thinking the wrong car? The 968 definitely has the battery in the front.
From BaT:
From BaT:
- 94 968: https://bringatrailer.com/wp-content/uploads/2022/02/1994-Porsche-968-RS820596-108-33276-scaled.jpeg?fit=2048%2C1366
- 938 968: https://bringatrailer.com/wp-content/uploads/2021/07/16253224102571b8f9754c2d1b68IMG_5577-scaled.jpg?fit=2048%2C1536
- 92 968 (peek-a-boo at upper left): https://bringatrailer.com/wp-content...it=2048%2C1365
- My 92 968 (also peek-a-boo upper left; horror stories there and here): https://bringatrailer.com/wp-content...it=2048%2C1367
The last picture of your 968 is the best one. Seems that the plastic engine cover is one piece. I'm afraid I have to remove the whole thing? Hope it does not crack...
-Yogii
-Yogii
Spokayman (02-23-2022)
I don't have the rear engine cover (and the front one is in my basement ...) but if I were you I'd pull the cover and fish out the wrench. Shouldn't be too difficult, and avoids the small but non-zero chance that it gets caught in the front hub / brake area and does something nasty. Of course it'll probably just fall out harmlessly onto the belly pan - in fact in might already be there, so maybe jack the car up and pull the pan?
Can you fish a bendy magnet thing down where it fell and see if you can pick it up?
I'm having some trouble visualizing how it could get into the wheel well. I second the vote for looking on top of the belly pan. There are not too many moving parts near the back of the engine but I don't think that you want it rattling around, and you certainly don't want it rattling around near the front of the engine, that seems like a recipe for disaster.
There's a lot of aluminum in the engine bay; hopefully a good magnet can help you fish it out selectively.
Good luck
Good luck
Well I did get a 40inch long bend thing with both a magnet and claw at the end.
Once, I got set-up, I could see the wrench. Took 3 tries to fish it out. Out of the 40 inches, I needed about 6 of them!![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
Took all of 5 minutes.
I wish all worries were so easily solved.
-Yogii
AKA 968 Novice
-Yogii
AKA 968 Novice
JimmyB (04-25-2022)
